Synchronous Buck Integrated Power Solution: TPS84620EVM-692
153
The TPS84620EVM-692 is a fully assembled and tested circuit for evaluating the TPS84620 4.5-V to 14.5-V Input, 6-A Synchronous Buck, Integrated Power Solution. The TPS84620EVM-692 incorporates a DC/DC converter with output voltage and frequency that are adjustable using jumpers.
  • Complete Integrated Power Solution Allows Small Footprint, Low-Profile Design
  • Efficiencies Up To 96%
  • Wide-Output Voltage Adjust (1.2 V to 5.5 V) with 1% Reference Accuracy
  • Optional Split Power Rail allows input voltage down to 1.6 V
  • Adjustable Switching Frequency (480 kHz to 780 kHz)
  • Synchronizes to an External Clock
  • Adjustable Slow-Start
  • Output Voltage Sequencing / Tracking
  • Power Good Output
Synchronous Buck Integrated Power Solution: TPS84620EVM-692  Р[Link]
Leave a Reply
