Temperature and humidity sensor with serial output
443
This is a temperature and humidity sensor with serial output that can be read with a computer. An LCD display could be used with minor modification. The unit is based on Atmega8 microcontroller. It uses LM335AZ temperature sensor attached to AVR ADC port and NONEYWELL HCH-1000-002 humidity sensor. [via]
Temperature and humidity sensor with serial output – [Link]
Leave a Reply
