TrH Meter: A DIY indoor thermometer plus hygrometer with adaptive brightness
955
1
TRHMeterPrototypeOP2
This project is about building a microcontroller-based digital room thermometer plus hygrometer that displays temperature and relative humidity on 4 large (1 inch) seven segment LED displays which adjust their brightness level according to the surrounding illumination. It consists of a closed loop system that continuously assesses ambient light condition using an inexpensive light-dependent resistor (LDR) and uses that information to adjust the brightness of the display. An inexpensive DHT11 sensor is used to measure temperature and relative humidity. The microcontroller used in this project is PIC16F688, and it runs at 4 MHz clock generated from its internal source. A separate display driver chip (MAX7219) is used to control and refresh the display data on the seven segment LEDs.
TrH Meter: A DIY indoor thermometer plus hygrometer with adaptive brightness – [Link]
One Response on “TrH Meter: A DIY indoor thermometer plus hygrometer with adaptive brightness
Leave a Reply
