Two-Channel PC Based Oscilloscope USB
1866
circuitvalley.com writes:
More and more experiments are now ‘PC-assisted.’ Also conventional acquisition systems are very expensive. Since portable PCs are today common and a USB link is a better solutionhere we present an oscilloscope using USB port of the PC that operates at up to 10 kHz with ±16V input voltage. It has much more improved features than the PC-based oscilloscope . The oscilloscope uses IC PIC18F2550 from Microchip as the main controller, which makes the oscilloscope compact as there is no need of additional power supply for the entire circuit board.
Two-Channel PC Based Oscilloscope USB – [Link]
Leave a Reply
