Versatile RGB LED PWM Driver
876
1
FD6LWA1FUI0SPZB_MEDIUM
Follow these simple instructions to build you own RGB LED PWM driver. This easy to construct, versatile driver board will allow you to make your own RGB LED driver that can be built into all kinds of lighting effects. It doesn’t need DMX or any other external controller to operate, just a suitable power supply. The firmware is available as a free download and the sequences fully customizable, so if you have access to a PIC programmer you can create your own range of sequences for use with the kit.
Versatile RGB LED PWM Driver – [Link]
One Response on “Versatile RGB LED PWM Driver
Leave a Reply
