Wago 2060 terminal blocks don’t overtop LEDs
281
obr1384_1
With a height of only 4.5 mm are new terminal blocks able to connect LED modules and LED panels aesthetically and with a maximal reliability.
There are numerous SMT connectors on the market, which are suitable for usage on LED panels but even in other applications. That´s why it´s a logic question – why just Wago 2060?
Firstly it is because of a sophisticated construction of a terminal block with a globally known and million times proven screwless spring clamp CageClampS. This clamp has an optimum pressure on a wire ideally responding to a wire diameter, i.e. the thicker wire, the bigger pressure. Also thanks to this is the max. allowed current up to 9A (!). Further, it´s possible to install solid and ferruled wires even without tools. By a simple pressing to a terminal block (for example by a screwdriver), it´s possible to insert even fine stranded flexible leads and by similar way also to disengage. Features of a clamp don´t get worse neither after multiple disengaging of a connection and they remain stable even after a long period of operation.
From other positives it´s necessary to mention a “balcony
Leave a Reply
