Wireless data transmission between two microcontrollers using KST-TX01 and KST-RX806 rf modules
619
embedded-lab.com writes:
A lot of times we need to keep track of data from a device or a sensor located in a remote location from the point where it is processed. In other situations we desire wireless solutions for ease. Using long cables, infrared (IR) or other means are often tedious and not loss-less. Imagine collecting pH level data from a chemically lethal or toxic treatment plant where human presence is highly health hazardous. Running long cables from the pH sensor to the control or monitor station will surely introduce noisy signals and signal-to-noise ratio will thus drastically decrease. The result is erroneous data acquisition and thereby false decisions may be generated. If infrared signals or other optical means including lasers are used, they will need good obstacle-free line of sight or expensive and delicate optical fibers. Thus the solution stays in the radio frequency (RF) domain. This article talks about interfacing low cost RF modules (KST-TX01 and KST-RX806) for transmitting data between two remotely located PIC microcontrollers.
Wireless data transmission between two microcontrollers using KST-TX01 and KST-RX806 rf modules – [Link]
Leave a Reply
