You can read DIP122-5 displays even at the direct sunlight
171
New graphic displays EA DIP122-5 series with efficient LED backlight are optimized for good legibility even in demanding light conditions like for example at the direct sunlight.
Graphic displays EA DIP1222-5 with a 122×32 pixels resolution feature an excellent contrast and an efficient LED backlight offers great legibility even in a low ambient light environment. They are equipped with a temperature compensation for an increased working temperatures range from -20 to +70°C, without necessity of contrast adjustment. Displays also feature a „superfast liquid technology“, ensuring a sufficiently quick response time even at extremely low temperatures (average 2 sec at -20°C).
Three colour versions are available: yellow/green, amber and blue-white. Yellow-green and amber variant is particularly suitable for outdoor usage and extreme light conditions, while an effective LED backlight enables their usage even in a low ambient light environment. Blue-white veriant is optimized with respect to contrast and is ideally suitable for indoor usage with or without artificial light and when low energy consumption is vital.
Displays contain 2 built-in controllers (PT6250 compatible), while every controller is assigned to 61 columns. For external communication an 8-bit interface is used. An external series resistor or constant current source is all that is needed for the LED background illumination. The displays are easily soldered to the printed circuit board or socket connectors can be used if desired. New graphic displays offer for a customer also a high flexibility in a possibility to use a graphic or a character display module for various versions of a given device. As a character display modules types EA DIP081-CHNLED (1×8), EA DIP162-DHNLED (2×16) a EA DIP204-4HNLED (4×20) with the same casing and pinout can be used. .
Further information offers the DIP122-5 datasheet.
You can read DIP122-5 displays even at the direct sunlight – [Link]
Leave a Reply
