Zener diode tester 1V to 50V
2086
1
Zener diode is a special diode, unlike normal diodes zener diodes are intended to work in the breakdown voltage. These components maintain constant voltage at its terminals. This is a circuit to help you find out what’s the breakdown voltage of your diodes.
  • Read  Vz  value of zener diode in Led display
  • Zener diode tester range: 1V to 50V
  • Two scales 5mA and 15mA test
Zener diode tester 1V to 50V – [Link]
One Response on “Zener diode tester 1V to 50V
Leave a Reply
