21 -
Everything posted by Anotherforummember
You have not yet played around with ISD series of voice record/play intergrated circuits? The series covers times from 10 seconds to minutes and all kinds of interfaces. These things are ancient. http://www.winbond-usa.com/mambo/content/view/36/140/
Soft start on a 555 timer
Anotherforummember replied to MrHeckles's topic in Electronic Projects Design/Ideas
Inductors consume more current at low frequency that at high frequency. This idea is better termed "hard turn-on" Noise is what triggers SCRs. monitor noise with o-scope. Add ferrite beads here and there. Use better swithces than voltage consumming mosfets, and use short wire lengths. Stick to the source. He knows what I mean. -
Allow me to demonstrate the difficulty of making and interpreting commands without encoders/decoders. Transmitter: 1. 555 Timer1 35KHZ carrier generator fed into input of an AND gate. 2. 4-bit Parallel to Serial shift register with command loaded on parallel inputs. This functions as a Binary encoder. Either a hardwired parallel data command per individual shift register, or 4-bit toggleswitch and just 1 shift register. 4-bit toggle to 1 register means you must toggle the switch manually each time a new command is desired. 555 Timer2 Baud Rate Generator is needed to drive the clock input of the shift register(s). 3. To transmit, a TX button enables the clock for Timer2 and enables the shift register to send data on its serial out pin Ser-Out. Ser-Out and Timer1 is fed into the AND gate and the gates output creates the needed modulated carrier for the IR receiver. Modulated carrier is fed to an IR-LED. Receiver: 1. 35KHZ IR-Module does not "decode" but only "filters" the carrier. 2. The IR-Module's serial output Ser-In now needs to be compared to some hardwired parallel data. 3. A Serial to Parallel shift register is driven from a 555 Timer3 Baud Rate Generator and triggered on Ser-In's first transition from idle. Add J-K flip-flop to this. 4. The received Serial to Parallel data is loaded into a 4-bit Magnitude comparator. This device compares its parallel input with hardwired parallel reference data. If the 2 nibbles match, its A = B output is set, else A < B is set, or A > B is set. 1 Magnitude comparator for each command. Most of the above is what USARTs do. Encoder/Decoders use their own usarts, magnitude comparators, and carrier generators. All in one package as opposed to 5+ discrete ICs. Here is an analog method. Some how you either manually press a 35KHZ carrier signal into an LED or use logic to send out a prefixed number if button presses. Well, the IR-Module's ouput Ser-In is fed to a buffer. The buffer charges a capacitor through a resistor. The priciple is to charge the capacitor to different voltage levels by sending 1, 2, to X number of pulses from the Transmitter. The capacitor voltage is fed to a bank of comparators. Lets say 1 received pulse makes Vcap = 1v, 2 pulsed for Vcap 2v, and X pulsed for Vcap = Xv. To interpret the pulse commands, each comparator connected to Vcap has its Vreference set to 1v, 2v, Xv. The problem is that 3 pulses will turn on 3 comparators, so you must make all the comparators into Window comparators. 1 Window comparator is composed of 2 comparators whos inputs or tied and Vref(s) levels are near each other. If Vin is too high the comparator stays off, and if Vin is too low the comparator also remains off. Ok, now how do you discharge the Vcap in order to receive another command? Add another timer, a Delayed Timer, that is triggered from either Ser-In or whatever. Once the timer expires it discharges Vcap. to ground level. When you said "easily available", why is an encoder/decoder not available? May not be at local shop that I can understand. But it may be mailed ordered. I mean, you might have to mail order parts regardless how the project is done.
Dual CMOS based timer problems...
Anotherforummember replied to Kain's topic in Electronic Projects Design/Ideas
Difficult to see how the circuit is functioning. -
LED sequencer-need help
Anotherforummember replied to esaunders's topic in Electronic Projects Design/Ideas
...Are you helping with the addition of another off topic comment directed towards me ???? -
Yes, I thought of adding electrolytes to the water such as salt. Fill a small cap with water and measure the resistance. The range is 400k to 1.5M Ohms. Add salt to this water. Add a lot of salt. The range is 20K to 30K Ohms. This require 500v to pass only 20mA of current. iceman302: By the way, is the water solution independent? May the water's contents be altered or is this to actually monitor real world liquids such as pool, fishtank, bath, sink.....?
where to get cheap PIC's
Anotherforummember replied to hatman's topic in Sell/Buy electronics - Job offer/requests
Where have you search, or better what do you consider cheap? Referencing 16F877A in 100 qty: Digikey ~ $5.40 - $6.00+ Microchip ~ $4.98 - $6.00+ Mouser ~ $4.68 - $6.00+ Futurlec ~ $5.30 + Most large selling distributors ~ $5.00 average. If you want cheaper than the already 100 qty price break listing, you might need to establish a contract with one of the distributors or Microchip. -
555 timer for automobille indicator
Anotherforummember replied to Goatman's topic in Inventive/New Ideas
YES. 51% duty suffices if you so wish to not use extra diodes. Either way no big deal. Use a standard Astable circuit with a larger than normal capacitor and high resistor value. F = 1.44/((R1 +2R2)C1). R2 10x larger than R1 for 50.xxx% duty. -
All is good now. Scuba got my board, did a little toasting to it. Board fixed and now in service. Still in service Scuba?
I think it may work.
