Shahriar
Members
  • Posts
    451
  • Joined
  • Last visited
Posts posted by Shahriar
  1. Hi
    ooooooooooooh
    I Myself found the answer and this is the greatest exprience in my life
    I had forgotton to solder one of the jumpers whic was related to -Vee Net,
    so we take this result that if you forget to solder -Vee then the NE5532 gets hot and the device do NOT work properly ;D so remember to count the jumpers when you finished soldering, but I expected Distortion in case the Lack of -Vee but why the things i said above happened?
    Anyway I am very happy
  2. Hi
    I have build a headphone buffer amplifier but there is a problem.
    at first the sound is weak then as the NE5532 becomes hot the sound increases untile the IC becomes very hot and then Hiss in sound appeares i have also made some changes, i have used a 100K Pot instead a !00K pot for every IC so that I can control the volume of all just by one Pot...
    the schemtic is attached...
    your help is appreciated in advance...
    Headphone_Buffer_Amp.pdf
  3. Dear Kasamiko
    I have never heard that someOne coul repair his Windows, I think you are not infected, all things that happend is that your Windows has been corrupted, uninstall you windows, and everything will be OK, to prevent this again, never install games on your computer, if you want to play games with your PC you should install your windows 4 times a year, try Windows XP with Service Pack 2, and it is possible use NTFS format.
    HTH
    Shahriar
  4. Hi
    I have a Multimedia headset (Stereo Headphone with Mic ), and I want to build a
    PreAmp for the Condensor mic, it has a stereo XLR 1/8" plug
    it is a very general headset and works with PC Sound cards perfectly
    Does any boady know the pin map of the Mic Plug,
    which of the following pics is correct? The model of
    the headset is 'GALAXY AP-860'.On the box of Headset is
    written (Mic:Condensor type),(Polar Pattern:Omni-directional)
    (Sensivity:-40db),(Connector:3.5mm Stereo Plug*2)
    ThanX in advance...
  5. Dear Trigger and Suraj
    You are right by changing the place of components we can rout the Board butcan you tell me that How designers of TV sets design the PCB in case there are more than 2000 components on a TV Chasis, Do they use special Softwares. If i have to place the Components manually, so what is the autoplacer good for?
    Thanx in advance...
  6. Dear Trigger and Suraj
    Thanx in advance...
  7. Dear darrin
    I have tried many ways for making PCB, Do not make yourself tired with making PCB, The Cleanest & Cheapest way is to draw your Schematic and PCB yourself and give the file to Fabrication...
    Today no one can do everything, Desinging, PCB, Soldering and etc. Spend tour time with designing and thinking about circuits instead of Seaching in PCB meterials.
    Protel DXP and Eagle are two good Softwares.
  8. Hi
    I am working on a project and I want to select a microphone through other 19 Mics to connect it to PreAmp. I want to select
    Mics By a 89c51, what kind of relay or switch can i use...
    ThankX in Advance
    P.S. if I use ordinary switch to select Mics Manually, Does Ordinary swiches make the Audio signal Noisy?
