Shahriar
Members
  • Posts
    451
  • Joined
  • Last visited
Posts posted by Shahriar
  1. Hi
    I attached that file to show that my device is going to work like the cicuit I have attached, the only difference is High current for my device.
    The circuit I have attached is a Current limited power supply. when The Battery wants to draw more that i.e. 1A the Output voltage drops to decrease current at 1A, when battery get charge the current decreases gradually down to Zero, thats when the battery has been charged to 13.8V, So it never get Over charged!
    My circuit is same just differs in Current (15A) and voltage (27V).
    Dear indulis
    I didn't undersatnd the Meaning of ""  regulate it to no more than 15A ""
    Can you explain a little more!!!
    Dear Ante
    I hope I had answered your questions!  ???
    How much voltage is enough to charge a 24V Battery?
    ThanX
    Shahriar
  2. Hi
    Someone has asked me to build a battery charger. The battry is a 24V / 150Ah from those kinds which is used in big vehicles. I think they Are called Lead acide battery!!! Am i Right?
    the battery is to be charged with a max Current of 15A! I decided to charge it with a circuit like the one I have attached, because of High current for my circuit, I decided to use TWO ATX (PC power supply) 12V rail. {They are 16A Nominal}, but the problem is how do I limit the current at 15A.
    I have an Idea, Tell me if it works:
    There is a pin in ATX Ps which is for Stand by, And PC pull it down to Start the ATX. I want to use a .05 Ohm resistor at the output and when Over-Current Happen, Pull this Pin Up? Can I have a current Control In this Way?
    Of course, I have to increase 12V rail of Two ATXs a little bit higher to creat 27V (13.5 + 13.5 Two ATXs in series) to Charge Batteries.
    ThanX
    Shahriar
    Battery_charger.pdf
  3. Dear Perseus
    Antenna theory is very complicated and any Shape antenna has its own specification and uses, but as I have seen in some SIMPLE remote controls, the Antenna shape does not have very Specific impression on the range. I am going to build it for some one, If I did it, I will tell you about the antenna shape....
    HTH - Shahriar
  4. Dear SupeR-NovA
    About 330ohm Res. For a Flyback PS, and Vi(min)=190V, Your calculation is right.
    About the output caps, although there are some calculation for them, but As I have
    Seen in many designs, if you put bigger Value, it would be better. But about the inductor, as you Yourself Know, You should use the proper Value. I attach a file which
    belongs to a complete 250W Forward design, but because the complete file was too big, I extract just the page you need. (the complete document name is "250 Watt off-line forward Converter". There are lots of Such documents on the web.
    I think your design is perfect. Build it and test it. It will work fine.
    by the way, at any circumistances, you need a Resistor at the output to discharg the output cap. because when you decreas the voltage, the cap remain charged and if you connect a low voltage device, then ...
    HTH - Shahriar
    250W-Forward.pdf
  5. Dear SupeR-NovA
    I was planning to build the same circuit.
    you asked: "how much power should i draw from the supply when there is no load connected? "
    You should draw current as much as the Controller doesn't turn off. because Controller Is supplying from an auxilary winding. the problem that I think you have missed is that it is impossible to build an adjustable 1-30V adjustable SMPS while the controller is supplying from an Auxilary winding. because imagine the output is 2V the the auxilary should be  i.e. 10V. now, if you inrease output from 2V to 30V then the auxilary will increase to 150V. (BLOW UP). you should use  a seperate PS for controller then  put a Resistor at output just for discharging output cap when you decrease the output voltage.
    you asked:" can i connect the 340v rail ground to the output ground or will this ruin the isolation?"
    There is a standard for SMPS called "VDE". it says that when the output is higher than 42V the output must be Isolated. For your project it is upto you. If you think it is difficult for you to decrease the voltage down to 1V with using Opto coupler and TL431 (which is impossible if using TL431) then you can forget Isolation! but if you are going to sell your project, Isolate one is better! ;)
    about current limiting, I think both of them are good but I think transformer one would not be very accurate. I am not sure about this. it is just a guess! I have seen in some schematic that they use the Output inductor as a transformer to determine Over current. There is a document on the web which it has good information for current limiting. it is 6.3Mb  :o . Search for it. its name is "Current Sensing Solutions for Power Supply Designers"
    By the way, The output ripple of SMPS is much higher than a linear one at least 30mV. this is why I Decided to use a  LDO at the output of the SMPS then Keep the SMPS output 0.2V Higher than the output. In this case the Power dissipation would be 1W at 5A. Some more benefits of this was:
    1- the output ripple was very Very Good.
    2- Accurate Current limiting was possible with resistor without increasing the output resistance of the PS.
    3- I could decrease the output down to 0V. Because with using a TL431 and Optocoupler, it is impossible to decrease the output voltage lower than 3.7V. althought at lower voltages than 3.7V Power dissipation would Increase. but it is not a matter.
    HTH - Shahriar
  6. Dear jeevan772006
    Once I had made a distributor Amplifier with NE5532 IC. I had the same problem, after a few hours I found that I had not Place one of  Jumpers which was related to -Vee Rail. So All of ICs didn't have a -Vee. As soon as I connected it everything went right!!! I was really surprised How it was working... ???
    I don't know Wether your circuit has any -Vee or not, I just told this to remember Sometimes strange things happen... ;D
    HTH - Shahriar
  7. Hi
    A university expert has said that:
    Imagine a transformer connected to a Ac Voltage (between Phase and Nuetral i.e. 100V).
    it has an output of i.e. 12V ac.
    If you connect this trasnformer to the same AC Voltage (100V) which this ac voltage is comming from Two Phase which have 100V then the output will not be 12 V and is lower than That.
    {I mean, Imagine you have connected two Phase to a transducer and this transducer gives 100V rsm at its output then you connect this output to that trasnformer, Then The output will be lower}
    I myself have not tested this, it is just what that expert has said and asked to look for the reason?
    Is it possible?
    ThanX
    Shahriar
  8. Dear boombar
    I am not completelty sure but you can do it with those normal Regulator circuits. if you need a good regulation, maybe connecting some zeners in series and a suitable transistor with Vce >= 100V with high enough hfe.
    if you don't need 400V fix, then you can use two 30V zeners. just change the Resistor and zener place in the following Picture.
    HTH - Shahriar
  9. ThanX all for your replies and your Pictures.
    At last I made this circuit working. I was sure about my circuit wirings and I was really disgusted. Do you know How I solved it. Look at the picture below:
    I don’t know much about Zero and Poles in Feedback circuits. But I think this cap will do something with Poles of the circuit. Before this I thought these poles are not very important…..
    At last I connected the output of circuit to Oscilloscope, Wow, without that cap that output was oscillating very neatly and as soon as I connected the Cap the output was a Clean +5V DC Voltage. I have attached the output signal without a cap.
    Dear Staigen
    ThanX vey much, I think you solved the problem. the time difference between your replies and when I read them, causes I work a whole day on circuit. when you type the replies I am sleeping and when I write questions, you are sleeping.
    at last If I had checked the ouptput with an Oscilloscoe then I would take result a 12hours earlier. 8)
    Dear Audioguru,
    are the values which you have written, from a circuit or you have witten them from simulating. anyway, I am going to test the circuit you have drawn. (I build the circuit on a BreadBoard!) :D
    By the way, when I just Inserted a 1nF cap between Pin3 and Pin1,(while there was no output cap) the output was still oscillating but the amplitude was smaller.
    ThanX All again
    Shahriar
  10. Hi
    I want to build a Low Drop out voltage regulator(LDO)
    I tried the schematic Below but the output Changes when I change the input voltage.
    I wrote the voltages I measured at Vi=8V.
    I put that 8.2K and 2.2K to create a voltage devider at the base of NPN tarnsistor because the lowest voltage i could get of TL431 was around 1.8V So I affrade maybe the NPN do not gets Off.
    I put the other 2.2K to creat Enough current for TL431.
    the output of this circuit should be 5V. The reference voltage of TL431 is 2.5V
    ThanX in advance
    Shahriar
  11. Dear wood_workur
    As your writing implies, you want to sell these devices to customers. On thing that you should remeber is that simple transmitters Frequency will change by Tempreture, and even after a month or a year. So if you want to get rid of customers calls, you should use a PLL based design.
    If you know programing, maybe you can use a Data transmitter to send address to enable or disable Devices, As I know, it is really difficult to use that Data Transmitter to send a digital Voice. (because of Low Baude rate of that transmitters)
    But if you do this, adressing will be very easy and you can increase the devices much more than 4.
    At last, I should say that RF designing need Exprience that I am sure you have
    Hope success
    Shahriar
  12. Dear stevedabear
    As Ldanielrosa Said you'd better build one for yourself.
    About the file ANte Attached, I should say I couldn't download it because it is too big for me to download it. (I have a dial up connection)
    I have attached The thing you want. with all explanations. U can Download any other thing needed from the web site. but you should do that Old trick as we discused in this website to enables you to download from SILICON Website.
    Just Write the topic in Google and click on the Link. If you go directly to SILICON Website it does not allow you to download ;D
    HTH - Shahriar
    Silicon_Score_Board.zip
  13. Hi
    I have a SMPS that its output varies from 4V up to 32V. As you know at the output of most SMPS there must be a Load to Dissipate some power. For my SMPS, it should be at least 2-3W Because this SMPS is to be used as a Laboratory Supply, I have to put a load at the output. I can not use a single resistor.
    i.e.
    Vi = 4V  & R=8ohm    ---> P=V^2 / R = 2W
    But if  Vi = 32V then P= V^2 / R =  128W
    So I have to use a constant power consumption circuit. I designed one but it dissipate 8W at Vi=18V and dissipate 2-3W at Vi =32V and dissipate 3W when Vi=4V.
    I have not build it yet. These writing are from my calculates.
    This Non-Linearity is because  P is proportional to Vi^2.
    Does anybody have a good Idea?
    The schematic is attached
    My numbers are not very Sharp
    ThanX
    Shahriar
    ConstantPower.pdf
