zama
Members
  • Posts
    2
  • Joined
  • Last visited
zama's Achievements
Newbie
  1. I made the circuit as it is on the web. The thing is, that there was no reading of the ampmeter ( i have not reading of the ampmeter before ) when the power source came down, but the led wasn´t on when it happened. The load was a stepper motor of 1.4 amps per phase and 5 v, connected by a tanslator circuit of TIP120 transistors (that the have a protection diode), that were controlled via a circuit with the parallel port.(all conections were ok) I think that the problem has to be with Q1 as it is alreay on ,and i read a 45v betwen the colector and the emiter ,probably in the saturation region. I dont know if Q1 has burn out or just the negative rail is still at the the level of the shut down protecction circuit. Thanks for your support.
  2. Hi , i have built the power supply and for several try it has worked but ( it has never show me current at the ampmete rconnected in series with the positive wire) when i loaded suddenly, i just can read 0 v in voltmeter output. I dont know if it has to do with Q1 ant the shutdown protection or just Q1 has blown off. Any idea? Thanxs
