indulis
488 -
indulis's Achievements
And during the dead time... how is the secondary current circulating? Now, if that current were to flow through the secondary winding (changing flux), how would it reflect to the primary?
schottky specification in LCD monitor switchmode supply
indulis replied to mcbmcb0's topic in Power Electronics
You have to consider what the anode voltage will be when the diode is not conducting (when it swings negative). Also any spikes that may be there. -
In a multi output forward converter, calculate the inductance needed for the "higher" power output. Then, for the coupled filter inductor, the turns ratio between the transformer secondaries has to match the inductors turns ratio.
Where is the schematic? What is the output voltage & current? Where are you measuring the input current... directly across the I sense resistor? Do you have a RC fiter on it before the PWM Try to make it run without the active clamp first (just use RC or DRC snubbers).
Do a search for Llyod Dixon-Unitrode Seminars-Transformer Design
Any diode will work as a zener (PVI) but not very well. What makes zeners different is the “doping” levels in the N & P materials. By controlling the levels, the “zener voltage” (breakdown) can be "more" accurately controlled.
Think about it this way... first remove the current limit stuff (Q3, R4, P1). Then what to do with Q1... the collector-base looks like a diode... that "kinda works". I don't see how making Q1 a n-p-n will work at all. Then add the current limit function back in.
Need help with this voltage regulator circuit simulation
indulis replied to a topic in Electronic Projects Design/Ideas
Simplify the circuit... remove the OVP (over voltage protection) circuit... then it runs fast If you want to simulate the OVP function, do that by itself. -
You say it's an over voltage protection circuit, yet you ask if it can "drive a 3A load". I think your real question is can this circuit handle 3A... the IRFZ44 is rated for 36A at 100°C, so the answer is yes.
Look up a buck converter...
Orcad layout net and padstack width
indulis replied to masudasim's topic in Electronic Projects Design/Ideas
Try http://www.circuitcalculator.com/wordpress/2006/01/31/pcb-trace-width-calculator/ -
Where did you tie the "Adj" pin of the LM236-5 (D2)? It should be ties to the cathode if you wanted a 5V reference. Are you relying on "T1 & R2" to make it constant current? Don't!
You have a couple of problems... first, if the the supply voltage to the LM358 is 12V, the base of the BDX33C needs to be at least a Vbe drop above the emitter voltage to get 12V at Vout... you can't get there with what you have. Second, put a feedback cap on the LM358, say .1
What pic's? None attached.
What makes you think the kit is defective? Does the parts list agree with the PCB? Do the parts in the kit agree with the parts list?
