There is a transistor right beside it. There is print on the board that identifies the junctions as E-C-B. This on the other hand lables the terminals I -G-O Input guround and output. so Im fairly certain it is a regulator. I just need to find out what voltage it is The numbers I gave you are correct however there is a chance the part has been relabled. I know this because I found some other components where Im positive that this was the case. However Im not sure with this one. The only thing I do know is that it is a TO-92 case regulator with the numbers I listed in the first post. If you're unable to find anything with those numbers I stongly suspect that this one has been relabled also. If so then there is not much that anyone will be able to do. Thanks for your time.
