3 -
sputnikxxx's Achievements
Power Supply For tattoo Machine
sputnikxxx replied to sputnikxxx's topic in Electronic Projects Design/Ideas
ummm....? in laimens terms pleeze I appreciate your post to try to help I know the parts will work because I have done it before the problem is I cannot remember the exact wiring. if this can help basically the power goes into the rheostat to control the speed of the machine and the foot switch acts a circut breaker and is connected when pushed to make the machine run. but for some reason by mounting both jacks to frame it shorts it out -
As you can see from the picture that the power goes to the rheostat then the circut is broken by the foot switch and the machine runs when foot switch is pressed. I am no expert but I do have a general knowledge of electrical work. I cant understand when I tried running this set up the rheostat started smoking but when ever I unmounted the mount jack that had the machine running to it from the frame of the power supply it worked. Some how by having it mounted to the frame of the power supply it is causing it to short out the power supply I used is this one http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&product%5Fid=22-504 the rheostat I used is thisone http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&product%5Fid=271-265 the mount jacks used are these http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&product%5Fid=274-255
