microzone
71 -
Everything posted by microzone
Hi! I'm am Protel 2004 newbies. May I know how do I find 1N5822 and EE-Sx1070 (Omron slotted opto sensor) footprint and schematic diagram? Thanks for your kind help. :)
Can I solder L298n IC directly (without IC socket) into my PCB? Will this damage my L298n IC? Thanks. :)
Hi, I just bought a L298n a bipolar stepper motor I which is 15 pins IC. May I know how do I find its IC socket because I can't find this IC socket and just modify a 18 pin IC socket. It is not so good because it is easy short circuit if modify with this way. May I know has anyone has an idea or has seen this socket before? Can you please tell me? Thanks. ;)
I just get a stepper motor from my old printer and plan to use it but I do not know its connection. Does anyone has its data sheet? I guess it is a bipolar stepper motor because it has only 4 wires. My stepper motor information is as below:- QH4-4387 SMJ40-4878-A 24.12V 7.5ohm FDK
Can I use 2 phase H bridge driver (M3479-P) to drive an 4 phase bipolar stepper motor (M42SP-7)? It is because I cannot find a 4 phase H bridge drive. Do you have any idea? Thanks. :)
Can please help me to check whether I can use MC3479-P H bridge IC to drive my bipolar stepper motor which is M42SP-7? Because I really do not have an idea. Thanks you first for your kind help. :)
Thanks audioguru for your info. Besides this what should do I need to check for the Bipolar Stepper motor H bridge IC before I buy? Can you please give an idea and recommend some Bipolar stepper motor H bridge IC to me? Thanks. :)
I just brought a stepper motor H bridge IC and plan to use use it for my 12V bipolar stepper motor. May I know is this IC can use for my 12V bipolar stepper motor? How to check from the data sheet? If it is not. What kind of H bridge IC is suitable for me because I need and IC to control the motor speed and direction? Thanks. :)
Thanks, I have read the article called Pulse Width Modulation written by By Michael Adler and Tim Surtell at http://www.eleinmec.com/article.asp?28. May I know the mean of "The motor will work perfectly well, provided that the frequency of the pulsed signal is set correctly, a suitable frequency being 30Hz."? How do I set the frequecy to be 30Hz and how do I know my frequency is at 30Hz after setting? Thanks for your kind help. :D
Recently I have read a Simple DC motor PWN speed control circuit from http://www.electronics-lab.com/projects/motor_light/038/index.html. Inside the article and below the word of important, there have mention that "the drain (or collector) current must be equal to maximum motor current (at power supply voltage, when it is blocked)". May I know what is mean by maximum motor current? Can I check it from the data sheet (Which part of a data sheet, can you please guide me?) or measure from the 12V DC motor. Thanks for your kind help :D
I'm a conveyor belt newbies. I plan to construct a 60cm conveyor belt which would use to transfer a a glass of water. May I know what material do I need to use and how do I construct this conveyor belt? Can I construct this with my recycle printer? Because I really interested to build a conveyor belt but I do not have much budget. Thank you first for your kind help. :)
Hi! Expert and non expert are welcome to give your idea on this because I really do not have an idea on the conveyor belt. Thanks. :D
I need a vibration motor but I cannot find it. May I know can I modify a DC motor or stepper motor to be a vibration motor? If it is possible, how do I modify it? Thanks. :D
Thanks for all the elctronic experts kindly reply. Actually I need to build a conveyor belt with a dc motor which will only work in one direction and the conveyor belt speed is optimum to avoid spill a drop and only 1 glass per time. I plan to use PIC (a microcontroller) to stop the conveyor belt after the glass reach the destination. Actually I only an electronic newsbies therefore I do not know how to build a driver to drive the motor further more the motor type (12V or other voltage) is also a problem for me. Do you know what kind of material can I use to build the conveyor belt? Can you give me some precious idea?
Actually I need to create a conveyor belt to transfer a glass with water from one place to another place, distance is around 60cm. Is anyone has an idea to create a conveyor belt? Do you have the construction diagram? Thank you first for your kind help. :)
Sorry, Staigen. I'm an electronic newbies. Can any expert or non expert help me to solve my problem because I'm do not have any idea? Do you have any tutorial or good webpage to intro to me. My question is as below:- Hi! I need to use an infrared diode to calculate the number of coins drop, may I know what type of infrared diode is suitable? I also need to do use a motor to vibrate the coins to make it fall down the slope, may I know what kind of motor can I use? Thank you first for your kind help. :)
Hitachi hd44780 16x2 LCD data sheet
microzone replied to microzone's topic in Datasheet/Parts requests
