mvs sarma
234 -
Calendar
Everything posted by mvs sarma
Variable Power Supply
mvs sarma replied to ignitedindian's topic in Electronic Projects Design/Ideas
Hi, if you can scan the bundle of projects you find on the opening page of this site, you will go thro and you get a lot of data. eventually lot of diacussion posts are also on this topic and i am sure you will be stomach full . all the best for 2k7 -
Hi Brothers and Ssiters, WISHING ONE AND ALL A VERY HAPPY AND SUCESSFUL NEW YEAR 2007 WITH REGARDS, Sarma [email protected] 0 91 94401 54650
Hi A.R.mazaheri , Welcome to the fourm, i hope you appeciate that there is going tobe a power loss in the form ohest of 140Watts by designing a Linear reulator using LM723 form 65 to 45 Volts and a current demand of 7 Amps. Instead, you may consider Switching power supply to get a better efficiency. Sarma
Any math'a maexperts out there? Need help rearranging this formula...
mvs sarma replied to bobleny's topic in Theory articles
hI, iS THIS WHAT YOU WANTED IT I UNDERSTOOD PROPERLY? F= 1.44/((R1+2*R2)*C) (R1+2*R2)= 1.44/F*C 2*R2={1.44/F*C}-R1 R2=[{1.44/F*C}-R1]/2 Sarma -
Hi Hussainking, you may try PCB123 software is good infact. it claimed to be free. you can send the file to them and order pcb even. you may google for pcb123 Sarma
Hi, Don't ask questions -- just follow the advises already offered. if i were to be in you position ( abt me - a 61+ retired telecom engineer, still consider myself a dummy and want to learn a lot ) i would have finished a book or two by now. take any faulty board- afforda multimeter and a soldering kit - may be burn your hand --WARNING -- WITH CAUTION--- you will comeout ina month's time-- as you said already goof at fixing PCs -- just GO AHEAD- don't re think. all the best Sarma
Hi Panannto, You are Welcome, i add a comment- this site for ever SERVES too it is for youngsters to use it to grow their knowledge and try become practical and purposefull All the best-- Sarma
Hi, when you get a rectified dc, though varrying, the DC content is taken by the ic and the variation is treated as source or supply variation. still the control loop of the ic should give you a regulated o/p for obviously minimal load requirements.
Hi, if it is fast varrying, try a votage doubler with germanium diodes like OA79, etc, the output can be clamped by three silicon diodes to fgive you around 3XVf of the diodes. this provided the variation is equal at MIN and MX. otherwiase try MAX1724. it is said of capable of working from 0.8V. Datasheet at http://datasheets.maxim-ic.com/en/ds/MAX1722-MAX1724.pdf
Hi, In support of audio guru's opinion that you can work with one supply, attaches find a application note URL http://www.national.com/an/AN/AN-1525.pdf this will enable you work with single voltage.
Hi please elaborate your point-- not able to catch it-- you mean deriiving 12v from usb power supply (5V0 for your use in the circuitry used by u.? if so you may use any Dc-Dc converter ( for eg., MC 34023A in the boost mode. with few extra components and convert it to 12v for your use. Is this what you are trying to ask please!!
dual switching power supply question
mvs sarma replied to only_lonely's topic in Electronic Projects Design/Ideas
Hi the CC mode is preset for a known constant current-- hence no need to measure. if you are able to measure the total crt, you can deduct CC paramter and balance is taken by CV unit. -
Doubling 7805 regulator current is effective?
mvs sarma replied to wuemura's topic in Electronic Projects Design/Ideas
Hi Wuemura , Replace the D1 with 3 amp diode-- Go ahead-- try mount the transistors on the body of the poer supply cabinet ( if Metal) and insulate them with TO220 type packing kit. If plastic, try a heat sink of aluminum sheet of adequate thickness if you dont get the type suugested by Audioguru--you may try for 200 mA thro' 7805 by reducing the R1 value to 3.3ohms and 1/2 or 1 watt. fuse can be at 3amps slow blow as already recommended by GURU -
Convert 0-30V 3A PSU to 5A or more
mvs sarma replied to mixos's topic in Electronic Projects Design/Ideas
Hi Audioguru, Current sensing outside cct Voltage sense-- yes. I shall come back after a little study Fine sir regards Sarma -
Hi Perhaps an LM323 can do your job but very costly compared to LM7805 In fact earlier MC78T05 (TO220) were available - I saw few of them -- these devices used to give 3 amps laod provided properly heatsunk. if you get hold you may try -
Hi Audioguru i agree with you completely-- power projects , for that purpose any project soud be built with proper discipline-- i was only teeling about lead loss compensation from the power supply to the load point--( say 50 to 100 cm for each lead). this itself drops the voltage and the resultant voltage at the actual load would be ( expected - lead drop). this could be compensated by a 4 wire system. that all. regards sarma -
Hi audioguru you may recollect the type of power supplies that had two more wires(4 wire method) and the lead drop was taken care of and the voltage is corrected at the load-- i don't mean that we can then use thin wires and take the reisk of fire due to I^2*R loss . in specific case where voltage drop is to be minimised, in addition to proper guage wirs, this remote votage monitoring and correction maybe adopte for this supply also. regards Sarma -
Hi Bobleny Intead of asking whether someone is familiar with binary-- just think-- what heading you have designed-- i appeciate that you may perhaps be arning now-- coming to check-- i suugest that you try to breadboard it and have first hand experience-- or simulate on a softwaRE AND SEE WHAT HAPPENS- LIST YOUR PROBLEMS AND THEN SOME ONE CAN TRY HELP YOU REVISE THE DESIGN-- IT IS A PROCESS MY DEAR-- GOT THRO'. However you have not defined the displays and their MAX value. Shall I imagine that LSD as seconds,with max of 9, next one is seconds(tens) with 5 as upper limit, and the MSD is units minutes with 9 as upper limit ?? sarma
Dead accurate 1Hz clock signal???
mvs sarma replied to bobleny's topic in Electronic Projects Design/Ideas
Hi it is working with a single cell-- you need to level shift to TTL or CMOS in order that it is useful sarma -
Hi, Lovely TOPIC. there are time signals broadcast terestrially. like 10MHz, 15MHZ and many other. they provide time ticks at 1sce-- these are controlled by atomic clock . second , you should have DCXO- which provides a good standard clock and derive 1sec from this clock-- appears foolish is it not-- but when you used dead perfect 1sec pulse-- you may appreciate perhaps -
Hi Steven, What a lovely homebrue construction. Really fine. Congrats for theefforts and you have even damaged your finger while making this, I fear!! Few doubt here,
Hi Vivek, this is a Pulse Width Modulation SMPS chip. A good device in deed. I suggest that you may see the datasheet from www.alldatasheet.com
