136 -
Everything posted by windoze killa
The 72W is probably 72W PMOP which basically translates to the O/P power just prior to melting. There is really only one power measurement and that is RMS. It would be handy if you can find out what the RMS power of this amp is. Would be much easier to say if the speakers will handle it. If the speakers are a decent brand then the power of the speakers is probably in RMS and can probably handle the amps O/P.
Voltage level shifting
windoze killa replied to windoze killa's topic in Electronic Projects Design/Ideas
Well I actually need 5 OP amps as there are 5 currents I need to monitor so I can get away with 2 chips. The good news is that I have got it working with LM324s. Bad news is we are back to 5V supply and rail to rail amps. Hopefully I will have this sorted by the end of the week. Thanks for all the help. -
Correct. That means the fountain will spurt water differently for every song. Would be a bit boring if it didn't.
If you were to have specific filters for different ranges of frequency of the music you can have the O/Ps of the filters control different jets of water. Bit like the old musicolor light displays.
Good idea. Didn't think of that. Unfortunately I don't think we will have the real estate on the PCB. Pretty much why we are using op amps as we can get 4 in one package. And also the softies won't need to write anymore code. -
Guess what. In the process of building up my circuit I have been informed (after 3 weeks of toil) that I can have a 10V rail and have to use an LM324. Not bad seeing I was supposed to have this design finished last week. Oh well back to the drawing board. While i am trying to work this out I will be happy to accept any suggestions. -
Try putting a voltage divider with a pot on the other input to the comparator. Adjust the pot to cancel the small voltage you are seeing on the other input. You could even go a little further so you need a high voltage to switch the comparator.
You can make a 555 do almost anything. But what you require is a pulse, one that can be varied from 0s to 180s. You can do this using a pot and capacitors or you could do it with fixed resistors and capacitors and use a switch to select fixed delays.
Sounds like a pretty simple task. All you need is a 555 timer. There are plenty of circuits on the net that should do the job for you.
I can't think of any specific parts of the top of my head but there are heaps of ICs out there for driving 3 phase model engines. In particular brushless motors for model aircraft.
Terminating a cable with a metallic braid
windoze killa replied to Matt's topic in Electronics chit chat
The metalic braid you are refering to is the shield of the cable and is generally connected to earth or ground. If you are talking about a cable designed for audio then you can comb the strands out and twist them together. This and the centre conductor form an un-balanced cable. You terminate it in what ever way is required in the circuit. Now, if the cable is an RF cable then it is a slightly different matter. The metalic braid is still a shield and is always connected to ground and is also an unbalanced cable. BUT, because of the frequency of the signal the impedence of the cable and any termination will affect the amount of signal that is passed (this is also true about the audio cable but is less critical). As such any termination must be very good and the use of specific connectors is required. Also as I have called these unbalanced cables I guess I should explain what this is. An unbalanced cable implies that the 2 conductors are at different potentials and the shield is nearly always at gound potential. A balanced cable implies that the 2 conductors are balanced and at the same potential. Although a balanced cable doesn't have a shield they still do not radiate as much as one would expect. This is because the current flow in each conductor (when terminated in the cables characteristic impedence) is equal and opposite and tends to cancel the radiation. WOW. Now that hurts the memory cells. I could go a lot deeper but I will avoid that for now. More than willing to continue if anyone would like. -
You are partly right. This voltage will be fed into a micro but the I/P has to be 0V to 5V. The code in the micro is being used in many places and all the other inputs are 0V to 5V so we can't change the code just for this one. They are to be interchangable between each other. I will give you a little bit more info for this project. I have a bunch of current sensors measuring various rails of a power supply. The current sensors have an O/P of 0V to 5V for the range of current. Unfortunately 0A equals 2.5V. Negative current is 0V to 2.5V and positive current is 2.5V to 5V. We are only interested in the positive bit. The problem is we need a current sensor that has a 5V supply and can handle 25A. These are the only ones available in this range. -
A good rule of thumb concerning power supply caps is 10 uF per amp. Seeing as you require 6A then 60uF would be a good choice. As 60uF isn't a standard value the 47uf or 68uF would do the job. Capacitance is really only critical in switch mode PSUs. If you decide to go with a SMPS then I would think 100uF or higher maybe needed. Sometimes it is required to use a few caps in parallel to lower the ESR.
Certainly. But can we have a bit more info. Type of amp? Audio? RF? Type of active device?
14 3v LED's powered by 12-15vdc
windoze killa replied to alaskanvegi's topic in Electronic Projects Design/Ideas
You probably don't want to connect them in series. In this configuration if one fails none of them wil remain lit. This will also mean you will have to check each one to find the dead one. If you have them in parallel then only the one that dies will be unlit. Although these LEDs have a built in 470ohm resistor it maybe wise as already stated to include another. I would use a potentiometer on one so you can adjust it to an intensity you like and then measure the resistance and then replace it with a resistor that is close to that value. You would put this resistor into each LED leg. -
Something I always suggested to my students when they asked for a project was test equipemnt. Build yourself a capacitance meter or function generator or frequency counter. They are always usefull.
Thanks Pebe but I am not denying that it may work. It just doesn't seem to work in Altium designer simulation. When you pay $10K for a program you expect it to work. I am still obviously missing something. I have also put your other simpler single amp into Altium as well and it doesn't seem to work either. I can see I am going to have to do this for real. I was trying to save time and money and use the tools we have at our call but obviously I am doing something wrong. Also my OP AMP theroy is a little rusty. I will certainly be posting the results here so you know how I go. Even if I don't get this solved thanks to everyone thats tried. -
Pretty much yes. So long as you observe the power requirements of the earphone.
Well we need a load resistor. This shall be driving into an analog I/P of an AVR. With a load of 100K I get an steady O/P of 1.5V. 1M gives an O/P of 0V No load gives an O/P of 5V This doesn't make sense. I am obviously missing something. I shall pull out that dusty 20yo book and read some more. -
Still have a steady DC output but this time it varies withe the value of the 2 resistors and the load resistor. My head hurts. -
I haven't been able to build this but have tried to sinulate it in Altium designer. It gives a steady output of 120mV. I have tried to vary the values but it stays at a steady O/P around 100 to 150mV. My OP AMP theroy is obviously very depleted. Any more suggestions or variations?? -
Thank you. I think that is so close to what I have been trying to do. Will give it a try during the week. -
I am try to work out how to take an I/P voltage that is between 2.5V and 5V and produce an O/P of 0V to 5V. I only have a +5V supply to work with which is where I am having the problem. I have tried everything but just can't come up with an answer. There has to be someone that can trip over an answer.
