arsal_uet
63 -
Calendar
Everything posted by arsal_uet
like free chips is there any way to get free software cd's?
ok u willl see it tomoroe.ok.
but how can i get a constant dc level of 5 volts.
is there any ic which can give me a constant level of voltage even two volts or in other words is ther any ic which give a regulated DC voltage of 2 or 1.7 volts volts for the varrying 1.23 to 1.5 volts.
i have already tried what u suggested but problem is the ouput is still varying and i require a constant 5volt dc level.is there any ic which can give me a constant level of voltage even two volts or in other words is ther any ic which give a regulated DC voltage of 2 or 1.7 volts volts for the varrying 1.23 to 1.5 volts
i am designing a circuit. the problem is i want to make the potential difernce between two points which hav some varrying voltage to some commmon constant level of voltage.can u guice me how. consider the case below: in my ciruit: the potential difference bw two supposed points a and b is in notnal stat:1.435volts the potential differnce bw the same points considered during excitation is about :1.28 volts to 1.60 volts now tel me how can i make the varrying difference corresponding to one constant level,that is whenever i got the varrying output during excitatoin above 1.430 volts i got some constant value like 5 volts. plz guide.
i have to use atmel 8051 so can u plz tel me in accoradance vid that.thanks.
hi i want to use a realay, to conrtol a bulb of 60 or 100watt using microcontroller ouput. can anyone tel me which relay to be used keeping in view the controling parameter which wold be the dc ouput from microcontroller maximum of 5 volt and the bulb operating voltage which wold be220v ac. thanks for ur replies.
thanks to all of the contributers to my project. me got A++ grade in the project. but i wold strongly recomend that before doing anything just read the monostable operation of the 7555 ic. all the questions wold be solved bc how this circuit works and how the 7555 and the inciming signals works will be clear.
can u plz tel me what is the function of the capacitor c2 that is attached to the shorted pin 6 and 7 and then to ground.
H7555 ipa k9819ak
me asking for the calculations of the indutor indectance and the capacitor attach to it
another problem. my teacher has asked me to give him the comlpete design.can anybody help me here now
thanks sir u are always there to help me in my problems.
thanks for advice. can i do anything more vid this
guide me about making the frquency counter as i have recived the mobile incoming call through my rf coil. thanks for ur suggestions
my frind making a project and wants to know the data sheets of the foloowing ics: A683 4614 723 2N3055 D313 H1061
hi respected contirbuters. i got the circuit working today, but not because of the coil that is mentioned in the circuit but rather i took a rf coil from the market of about 10mH same as that is found in our radios. so mak it clear that u use the same as that is used in our radios of about 10mH, because its hard to make a coil the way its described in the specification sheet. I almost spent one and a half week on making it but of no use. now my circuit working and of about range of some a meter or a two.To exaplain to the teacher and my fellow class mates can u plz tel me that how at the pin 2 of the ic 7555 when the cal is incoming.i mean to say what actaully happen at that point. because there are two cirrents coming one from top tp dpen because of the batery 1.5 volts and secondaly the transistor.in other words can u plz exaplin the inner working just at the point pin 2.other i can understand a bit. Can u tel me how can i measure the frequency that is disturbing the coil just to make an additinal feature to the circuit. and what would be the ic that can be used for this.
in the ciruit suggested to me by someone here;in that circuit the 7555 has one pin empty. i grounded that pin and now the result is that there is a but high chnge in amplitude across the inductor but that is only about few millivolts and they are not being amplified by the transistor, so tel me how to mak the currnet in crease to mak the led turn on.thanks for ur suggestions all u guys.
plz tel me what is that RL stands for on that site, the link u given above.thanks for guidance.
problem is i have many solution thiking in my mind so asking diferent question but not geting exact design
how to desing the band pass filter of about 800MHz to 900MHz
can u plz tel me how it works?i mean how it determines the frequency of the circuit.
what shld i do then
what is the difference between the rf coil and the rf oscillaotor
