14 -
Everything posted by HANIFF
Hi I need some help finding the following TTL ICs: 74AS160, 74AS47, 74AS14, 74AS11, 74AS08, 74AS04, 74AS00. I need these for a project but having difficulty finding the parts. Thanks for any suggestions. Han
Friends, Could I have some more suggestions please. No luck yet. Han
Friends, I need a maximum of 8 pieces each. I need the ICs to do Laser project and I understand that only the AS series is fast enough for the transistion. Han
Friends, Sorry I was unable to respond earlier. I've been on vacation. Thanks for the responses. Han
Unfortunately Jameco does not list the 74AS ICs. Han
Thanks. I will try this source. Han
HELLO FRIENDS I need help finding the following ICs:74AS11, 74AS14, 74AS47, 74AS160 and 4002. Cannot find it at google, some TI and Fairchild distributors. If anyone knows where I could purchase these in small quantities I will be grateful. Thanks Han
Thank you very much. Its different from what I have but I will test it. Once again, thank you. Han
Thanks again for the response. I am looking at a DC range of 3-6 V Han
Thanks for the responses. I am designing an alarm using AC input and 5VDC output from the power supply. The alarm will be activated by a non-contact input/signal. When activated, if shaken or AC removed an alarm will sound. In the deactivated mode the alarm does not sound. I need to design a battery back-up that will allow the alarm to sound once the AC is interrupted in the activated state. I have designed a ckt. using gates, relays and transistor but I need to see other ideas of how to do a batt. back-up for the ckt. Thanks. I hope I provided enough info. Thanks again Han
I need some ideas on a battery back-up circuit that will work once a particular circuit is activated. The main power supply will be functional, but the back up ckt. will work only when the activated signal is received and the main power supply is interrupted. If the ckt. is not activated and the main power supply is interrrupted, the back-up is deactivated. Thanks Han
