581 -
Posts posted by mixos
You are pretty lucky HA :D . Here is what i found:
BT9151 is equivelant to UM9151 and it is a Pulse Dialer with direct Phone line operation. 4 * 3 matrix keyboard interface. Supply voltage range of 2 to 5.5 V. 22 digit redial memory. Selectable make/break ratio. High speed test capacity.
and this is a usage schematic:
I attach you also the UM9151 Datasheet -
Yes it is a good oscilloscope, but it is around 20 years old.. so there must not be an electronic version of the manual..
If i find it i will put it to the site!
I have already e-mail manufacture. -
This link really doesn't work, but I found this:
http://www.scientificindia.com/pdf/HM205-2.PDF
accessing the folder http://www.scientificindia.com/pdf/
which unfortunatly isn't the manual but the specifications sheet. :( -
You are right..
I corrected the above links.. please retry. -
I attach you a datasheet for 1200P60, I am not completely sure if this is the right one.. check it..
About BT9151 I can't find anything.. can u give more info? what is it? -
Yes I tried many sites (including manufacture's).. forums... groups etc.. and found nothing..
I measured the AC voltage across the transformer at
1V/3A the output was a distorted sine with 32V amplitude
and it goes till:
1,4V/4,4A where the output was also a distorted sine with 31V amplitude
Is the transformer goes to current saturation?
At these outputs except the Q4 also the rectifier diodes becomes hot. -
After further investigation this can also be caused from OFFLINE browsers that download all the site.
Important Notice: Don't use site rippers, copiers, downloaders or offline browsers. This kind of software causes overload and the site goes down!. Please respect this, otherwise your IP will be banned. -
Does anyone has a manual for that oscilloscope? I pay for a copy of it ;) -
The last two days (14-15 Jan) two IPs (already reported to their ISPs) attacked the site causing to go offline for some hours. Hope they find something else to play and leave us alone.
Here it is:
Thanks for sharing it with us? :D GREAT jod!
I will add a link also.. at the links section.
A little bit later......
Here it is: http://www.electronics-lab.com/links/?c=79 -
Check here:
http://www.hanssummers.com/electronics/clocks/clocks.htm
some great clocks... but are stand alone. -
The conversion of electrical pulses to mechanical vibrations and the conversion of returned mechanical vibrations back into electrical energy is the basis for ultrasonic testing. The active element is the heart of the transducer as it converts the electrical energy to acoustic energy, and vice versa. The active element is basically a piece polarized material (i.e. some parts of the molecule are positively charged, while other parts of the molecule are negatively charged) with electrodes attached to two of its opposite faces.
When an electric field is applied across the material, the polarized molecules will align themselves with the electric field, resulting in induced dipoles within the molecular or crystal structure of the material. This alignment of molecules will cause the material to change dimensions. This phenomenon is known as electrostriction. In addition, a permanently-polarized material such as quartz (SiO2) or barium titanate (BaTiO3) will produce an electric field when the material changes dimensions as a result of an imposed mechanical force. This phenomenon is known as the piezoelectric effect.
Piezoelectric Effect (PPT, 89kb)
Source: http://www.ndt-ed.org
more here: http://www.ndt-ed.org/EducationResources/CommunityCollege/Ultrasonics/EquipmentTrans/piezotransducers.htm
I think that Piezoelectric Transducers are used to our mobile phones to make them ring, or i am wrong ?! -
The LM317 calculator is here:
http://www.electronics-lab.com/articles/LM317/index.html
be sure to check it . ;) -
Datasheet 8085
http://digilander.libero.it/rar2k/TRS80/Intel8085A.html
Datasheet 8255
http://jap.hu/electronic/8255.pdf
Datasheet 8251
http://www.moxsyn.com/@ltera/c8251.pdf
Datasheet 80c85's
http://www.oki.com/semi/datadocs/doc-eng/msm80c85ahrs.pdf
Datasheet 82c51's
http://www.oki.com/semi/datadocs/doc-eng/msm82c51a_2rs.pdf -
The best site around ATX power supplies (or generic switch mode power supplies) ;) :
http://repairfaq.ece.drexel.edu/sam/smpsfaq.htm
Nice pdf billy :D -
When i tryed to test the software alone (without hardware) the same error apears in Win XP Pro. This is clear that has to do with the software constuction. I suggest to e-mail the author here: natan[nospam]email.si (don't forget to replace [nospam] with @)
Also try to istall this on your system: http://www.electronics-lab.com/projects/pc/020/port95nt.exe
Or try this PC thermometer: http://www.electronics-lab.com/projects/pc/016/index.html
I have tested it and it works nice, it works with the joypad port.
Don't forget to report back any corrections. -
Can anyone suggest any interesting chips that availaible as samples? I am starting with some:
MAXIM
MAX038 - High-Frequency Waveform Generator
DS1869 - 3V Dallastat Electronic Digital Rheostat
ICL7107 - 3 1/2 Digit A/D Converter LED
DS1920 - Temperature iButton
DS1620 - Thermometer Sensor
TEXAS INSTRUMENTS
TPA1517 - 6-W Stereo Audio Power Amplifier
TMP100 - Digital Temperature Sensor with I2C Serial Interface
UC3770 - High Performance Stepper Motor Drive Circuit
MICROCHIP
MCP42100 - 100 K Digital Potensiometer
PIC16C765 - 24Mhz, 256 RAM USB, USART, 8ADC, PWM 2, 3+WDT
any others? -
Here are the rest ;) :
39VF160 Flash Memory
www.mcu-memory.com/datasheet/sst/39vf160q.pdf
http://www.sst.com/downloads/datasheet/S71145.pdf -
Great Work Billy. Thanks for doing that :D .
Sometime ago an internet friend told me that the kit companies are making some small faults (not by chance) on schematics to prevend them from copying :o ! If you relly on the PCB, everything will work nice, becuase it's a copy of the original (already worked) board. So you can use it to debug the schematic.
Please do the debuging and make the changes to the schematic... i will be very happy to see it here! -
The transformer i bought was rated at 3A, but seems to be able to give more that this :D ! Also i didn't touch anything on the current limiter circuitry, I just set the current limit to full, that the strange!
Staigen: I haven't done the testing yet. Sorry for that, you will have to wait some days.. ::) By the way, I am happy you are an expert in PSUs that's give me some hopes to make this power supply even better :D, we hope to continue sharing your knowlebge with us! But can you be a little more detailed...
Why the case must has a 25 C, and not let's say 120 C (200C is the max temp that can affort this part) with a radiator of course.
"At 3 Amp output the rectifier is delivering about 100 Watts" Why so much watts?
Please help us understanding how you think in every result you post. So less experienced peoples will learn something!
Hope i am not getting bored. -
Yesterday I received a report from a user, read it:
I have an update for you regarding the transistor tester as I was having a few problems in getting it to work well it works now as a few modifications have been added such as connecting pin 8 of the 4027 to ground and then linking pins 3 and 9 of the 4027 together it then works.
once again many thanks mike it is a good site.
keep up the good work from kev Tellyaddict42[no-spam]aol.com .
Anyone that don't succed with this transistor tester can try this solution and post comments here so i will make any suggested corrections on schematic.
Thanks
Convert 0-30V 3A PSU to 5A or more
Posted
Which is the relation between the number of the output transistors and the output voltage and current?
If we put for example 2 output transistors in parallel, the output current we can draw is doubled (theoritically if the rest of the circuit can affort it)? shall we change the rectifier diodes or something else to something more powerfull?
And what about the voltage?
