Captain Nguyen
26 -
Everything posted by Captain Nguyen
Hello, I have tried to make of countdown with many 1N4148 and CD4017. But first led has weak licht and at last led has much light. See animated gifs. So I will make to get this. Like as this but there is more. (above the voicebox are 4 leds) And cruise leds controls will last on.
10A 1.2 to 20V power supply
Captain Nguyen replied to Captain Nguyen's topic in Electronic Projects Design/Ideas
I have thinking about this. I will made from 10A into 5A. 10A is too much for my projects. -
Knight Rider with Halogen Bulb
LOL......... ;D -
Nothing ;D I did not use when I drive. -
I have already break lights up (all-on) then knight rider effect. My Power Supply are to weak to get break light up. So, you see this effect when I try get break light up then knight rider effect. http://www.captain-nguyen.nl/knightrider/videos/NewScanner20Watt.wmv -
Schematic works ;D 8) -
I understand, Thank you. -
MJ15004 use 250W. :-X Have not looking to datasheet. Datasheet MJ15004 Is this schematic right now? -
I have found this schematic from internet. But I have adapt from 2A to 10A power supply. Could this work?
Long time ago yes. But with 1K resistor will it quicly turn of?, and without? Slow to off? -
Simple O2 meter with LM3915
Captain Nguyen replied to wuemura's topic in Electronic Projects Design/Ideas
Hmmm with LDR? Why not from lights? -
He say: With LM3914 work much better than LM3915. I think you read the level better with LM3914 than LM3915. -
I have got only 10 LED air/fuel gauge version, with LM7805 As you would like get circuit diagram here is it. -
I use with PIC16F628. But I must learn how write pwm effect in Jal. -
Thanks for info. And it work now with tip32. I did not use always. Only for show at meeting or friends. -
Okay, I will use 1 W resistor. -
Thank you, And resistor of 27 ohm. Is it 1/4 watt or 1/2 watt? -
Like as this? Or must I replace from Tip41 to Tip32? -
oh, I have wrong. It's Tip42, not Tip32. ::) And it's for car. With relay hear you all the time when it on. :o It would not like it. And this schematic from http://ratliff7.tripod.com/counsel.htm would not work best. I have hear from other forum. They say it does not work best, It would very heat. So, how dit they do that? Like as Knight-f2k4 scanner. And could this work at first schematic? http://www.electronics-lab.com/forum/index.php?topic=2373.0 -
Hi, I'm new here, and come from holland. I have one problem. I have made my Knight Rider Scanner with PIC16F628. Only LED will work, but no halogenbulb. I have tried with this schematic.
