4 -
Almost-retired's Achievements
This still doesn't, and nowhere in this thread has it been mentioned exactly what the definition of ESR is. Simply put, its the Equivalent Series Resistance, the equ of sticking a resistor in series with the capacitor. This is, or was 10 years ago, a difficult to measure item, and often the old eyetube cap checker was relied on to test this, but its a very poor test, done at an applied frequency of 60 hz. Many times better is a meter I ran into about 10 years back, fairly pricey at about $175, is called the Capacitor Wizard. It measures the capacitors resistance with a few millivolts of a 100 khz signal, and can indicate clear down to an effectively pure capacitor by shorting its leads. Its very very good at measuring the first 10 ohms of the caps ESR. It will let you repair stuff that no other failure indicator can find. Trust me, you don't want a 470uf capacitor in your critical circuit that doesn't measure under 2 ohms with this meter. <0.3 ohms is good, but some new ones won't quite hit that low a figure. Even 2 ohms can lead to serious heating and poor performance of the system in some cases. Serious enough heating of course leads to alu foil, antifreeze and smelly kraft paper all over the place, hard to clean up in tight places... -- Cheers, Gene
Well, since I posted that, and didn't get a reply until now, I've since found some motor drivers that are probably even better for about $18 a channel at http://www.futurlec.com. The SMCCV2. Ready made cards, just mount, move the input jumpers, and cable them all together 3 to the cable. They also have a dual 8255 board, (PCI8255) giving 72 lines of I/O for around $75, also with that same 34 pin IDC header for a connector. They all daisy-chain on a hunk of 34 pin floppy cable so that you can select on the individual motor driver board whether it responds to portA, portB or portC of the particular 8255 you are plugged into on the pci card. Coupled with a $16 5/+12/-12 volt (#TMO2PWS4574) with independant ground for the 5 volts psu from Herbach & Rademan, and a handfull of their 24 volt 1 degree, 23 oz/inch steppers (TM93MTR2344), I'm down to doing the software, and actually hooking the motors up to the handwheels on the mill. I have shaft couplings machined for the motors, but I'm still mulling over how best to actually mount the motors and mate the shaft couplings to the hand-wheels. Probably by cutting little pieces of steel out and rewelding them into the finished product with my mig welder. I'm still designing that part as I'd like to be able to pull the motors out of engagement with the wheels, and then let them hinge down, or to one side and out of the way. Its somewhat complicated by the fact that the bearing houseing the mills drive shaft can enter the base casting by about 1.020" in both the x and y directions and that makes the motor mount shaping a bit of a problem unless you can weld, or have a metal brake able to do 14 gauge steel. I don't have a brake, darnit. Nor a sheer able to handle 14 gauge steel, so that will exersize my 70 year old arthritic joints a bit cutting all that out unless I do that on the mill too, slow though. But I'd imagine thats a bit hard on one of those dremel 1/8" solid carbide bits unless I can rig continuous cutting oil to it. I've also found that Bosch makes a solid carbide router bit, 1/4" upcut spiral, that can toss alu swarf all over the place, limited only by the puny power in the mill head itself. About a $20 bill at Lowes. I've carved up a pound or so of alu with it so far and no sign of dulling yet. Keeping it wet with oil to seal out the oxygen no doubt helps, as does cutting shallow but rapidly to reduce the time for the oxide film to form as the fresh alu is exposed by the cut. The motors I have, are 8 wire motors, so I can do them as 12 volters by paralleling the windings that would normally be driven one at a time, and use the pwm current limiters built into the driver H-bridge chips to control the heat, still banging them with about 30 volts at the turnon point. So I should have well over a kilohertz in stepping frequency while maintaining decent torque. Now if I can interface that dual 8255 card to linuxCNC for the software frontend, using some of the sample code that came with the driver boards, I should be home free by the time the snow flies here in WV, USA. Or so it says here, but the pci card has not arrived yet. And I am going to argue with my card issuer, the prices on the futurlec web page are in USD, but MC is charging me approximately a 10% premium for the USD->AUD translation. So beware of your card if you order from futurlec. However, the fabrication quality looks very well done and I'm impressed for the about $18 they cost. Thanks for the reply. I may be back with more questions if I hit software problems, but beware, there is no M$ software allowed in this house. :) -- Cheers, Gene
Greetings from a noobie; I found the 3 axis controller board kit thru a google search thats made, or was made, by [email protected], and which looks to be exactly what I need for the controlling of a micro-mill. Unforch, it appears [email protected] seems to have an overloaded mailbox, has some sort of a password number driven intercept on his 800 number, and just plain isn't answering the normal phone number that fell out of a google search just now. I also see that he is no longer selling to the general public in qty's less than 5. This looks like a decent board, particularly for someone like me to attempt to run a micro-mill with. I downloaded all the stuff required to build it, but I'm not really equipt to handle pcb etching here at the old folks home aka The Heskett Ranchette. :) I got spoilt many years ago when the tv station I started out doing a bit of engineering at back in '64 had a DEA spray etcher, which made short, and extremely precise work out of pcb etching. Rather impressive to see the notes you made in the 10 by grid under the layout mylar, come back out of the etcher perfectly ledgible and .025" high in 2 oz copper after a 4x reduction. Is anyone else here on this list makeing up this kit and selling it? Or has it been sold to a commercial operation? Please reply (prefereably in plaintext) to: [email protected] In addition to the list. Many thanks Cheers, Gene
