kachew
Members
  • Posts
    104
  • Joined
  • Last visited
Posts posted by kachew
  1. hi audioguru,
    i think i know what is kachew tryin to deliver.... ;D the concept can be found in any power electronics book ;D ;D and i also attach a circuit i think is similar to your concept using the cd 4001....and audioguru can u try to explain your circuit using the cd 4001 and mosfet as a switch?  the center tap transformer is similar to 2 transformer circuit as i attach? thanks for your information and reply ;D ;D
    Figure.rar
  2. hi audioguru,
    i think there is some problem due to the circuit....i think the CD4047 and CD4001 can be act as the control circuit for the swithing circuit which must consist of four mosfet in order to get the modified sine wave?? in the 1st cycle the signal from the control circuit will go trough the 1st then to the 1st winding of the transformer and back to 4th mosfet to get the +12V at the transformer and get the positive pulse at the output of the transfomer. in the 2nd cycle, the signal from the control signal again pass through the 2nd and 3rd mosfet again to get the negative pulse at the output of the transformer....
    pls comment and thanks for your reply
  3. dear audiouru,
    Sketch the circuit of a modified sine-wave inverter and I will check it for you. Don't forget the transformer must have an output voltage about 1.414 times higher than the transformer in a square-wave inverter, to create the peak voltage of the sine-wave. Therefore instead of a 230V to 24V center-tapped (12V-0-12V) transformer you need a 230V to 17V center-tapped (8.5V-0-8.5V) transformer
    may i know wat is the power rating for the transfomer???is it usin the equation p=vi? is so in order to get 150w at output 220v then we need 0.68A and at the input then we must have at least 12.5v?
    how about i add LM358 amplifier to increase the output current from the CD4047 in order to increase the efficiency?
    At only 50Hz or 60Hz, I don't think the switching speed makes any difference. If it was 50kHz or 500kHz then a lot of current is needed to charge and discharge the high gate capacitance of the Mosfets for them to switch quickly so they don't get hot. An LM358 is about the slowest opamp that is made, even slower than an old 741 opamp. It would be lousy for driving Mosfets.
    tought u said this to me before??? why call me to use the LM358 again??? or do you have any other suggestion???
    The 100k resistors in series with the capacitors at the transformer have way too high a value to do anything.
    Au arent the resistor used for the current equalising and as pull down resistor?? how about compare it with sasi inverter using the mosfet??
    thanks again...
    for the mosfet...the low turn on voltage means that the resistance inside the mosfet must be low enough to turn on the mosfet ??? by equation V=IR???
    thanks for your reply.... ;D ;D
  4. dear audioguru,
    is it the 396us is the operation cycle for the mosfet?? so its take to 396us to amplified the voltage in the 1st mosfet in the positive cycle and the same time to amplified the negative cycle in the 2nd mosfet...so is it u mean that the resistor in the gate mosfet the larger the better to provide sufficient time to have to cool down time for the 1st mosfet? or the smaller value for the resistor for fast switching??
  5. dear audioguru.,
    thanks for checkin the circuit for me... ;D ;D and so sorry for the unclear circuit coz i draw and use digicam to take the circuit i drawn...audioguru do u hav any recommendation for the software to draw the circuit...coz i dont have any software for that...and for the comparator part shall i change to the opamp?? which opamp is more suit for the inverter? for the power mosfet i will try to find a suitable 1 and redesign the circuit as u guide me...thanks
