nikolaw
32 -
Calendar
Everything posted by nikolaw
heloow i need step motors please help me
Where i can Bay online step motors? can you tall me some web pages????? thanks
Where are you from?
All is ok on board only one UCN5804 broke down and i replace that UCN whit another and everything i s ok bat what can burned UCN's i Use power pc suplly is this big supply? should i use 1. small power supply (i mean in A and V) 2. or use fuse 3.how mach is max volts and amperes of power supply what I can use for this board
I have a problem I build another Bord but one chip broke again i use http://www.doc.ic.ac.uk/~ih/doc/stepper/others/example2/ and PC power supply What is the problem ??? ??? ??? :'( :'( :'( :'( How much Volts and Amperes i mast to use ??????? PLEASE HELP ME
how do u men i over heat the UCN chip?
my step drive dont work any more :( :( :( ucn is broken i bay new ucn' and thy broke too what is the problem :( :( :(
can you send me full schematic for something bigger thanks mp
WHERE I CAN FOUND schematic FOR MORE THAN 1,5 A FOR BIGER MOTORS THANKS
I use XP go in your BIOS (pres delete key wen your pc start ) and use &H378 in port setup
go in your bios and select 378 port in port setup i use wp
i use XP and u mas to do this go in port setup an do like the pic 2, 3, 4 - x-, y-, and z-axis step inputs, respectively. 6, 7, 8 - x-, y-, and z-axis direction inputs, respectively. Direction polarity depends on the motor connections. (to switch direction polarity, simply reverse the motor connections end-for-end) 13, 12, 11 - these PC connections are used to bring the controlled machinery (i.e. X-Y table) to a "home" position. Normally open (N.O.) switches are used here. u mast select &H378 or like in your bios see what are you have in your bios port setup and select bedirektion in your bios
yes everthing works fine i made x , y mashine now i building z i will send soon u video of this mashine
can u send me some pic from your mashine??? this is the board , now i build mehanic :) thanks
and who program is best for you? what caind of step motors do u use?
what program do you use?
I made the board with ucn5804b I connected it with KCam 4 CNC Controller but the step motors are not working how can I adjust the parallel port? how should the picture that I put look like? ??? ??? ??? ??? ??? ??? thanks
thanks man you are super!!! ;) ;) ;) ;) ;) ;) ;) ;)
if i understand i mast to do this???????
hi if i understand you i just need to connect 12V on place were i connect 5V???????
I use this projects http://www.electronics-lab.com/projects/pc/008/ but i have step motors who work with 12V how can i conect this steps whit the board please help me? can u give me mail or msn or skype my mail is [email protected]
hi my problem is this i build board on this proekt whit UCN5804B this board use +5v power suply but i have some step motors whit 5 wires who works on 12 V how can i conect this motors whit this board whet they need 12 V to work this motors are from 5,25 floppy (the old one) a what to build CNC who will work whit KCam 4 CNC Controller can you help me pleas pleas
tahks MP but where i mast to connect +/-12v power for step motor how? please help me? :'( :'( :'( :'(
i need help plaese :'( :'( :'( :'(
