CALAHAN
71 -
Everything posted by CALAHAN
Guru, I consider this another success. The first communicator I built, which started this thread, was modeled after the "Alpha" communicator as coined by the folks at www.herocomm.com. This second build is modeled after "Gamma". Of the 10 communicator props built by the prop master for the original 1960's Star Trek TV series, only 4 have been found as of yet. This radio is using a Motorola Walkabout FV200. It has the LCD screen and the GMRS channel range etc. The channels need to be changed from the back after unscrewing the back shell. However, one need only set the channel and volume and as long as the batteries stay in, the radio will default to whatever is programmed in it. Because of the use of the Playmtes toy sound effects chip, it has the authentic "chirp" which sounds with the flip of the lid, and the hailing beeps are activated by a tac switch on the back. I placed a slide switch hidden in the Velcro on the back also. This powers down the MC34119 audio amp so as not to suck battery power when not being used. At the start of the day, just slide the switch over and the speaker is on. The right control button is Xmit, and the left is the on and off button. The middle jewel lights up when the unit is powered on and flashes when in battery standby. I found a capacitor on the circuit board and jumped the LED off of it. The LED has a maximum forward voltage of 3.5 volts , and the tester on the one leg of the capacitor shows a fluctuating voltage never over 3.2, but I put a small value resistor on the negative end of ther LED anyway. I field tested this with a custom built antenna and was able to communicate around a 10 story building in Downtown Chicago, and then stood at 20 S. Wacker and spoke to a guy on another FRS due North at Illinois street which is about 1/2 mile. That is pretty good in the Loop with all of the metal and buildings. As with any FRS, the range is dependent on what is in the way of the signal. FRS radios do not like elevator shafts! At this point I have the original antenna in it, and will be field testing it for range this coming week. The signals are not quite as good as the original radio because of the location of the antenna being now internal, but it will do what I need it to do. Thanks Guru Bruce
I think I'll stay with my switch for what I have now on the MC34119, but if this new IC you recommend has merely those little solder pads used for PCB's I'll have to have new glasses - I have about had it as it is :) Bruce
Guru, If I buy a few of these, can I use the same configurment as the MC34119? Are the pins the same etc. I haver a found places on the web that still sell the MC34119, but places like Mouser have them discontinued. Also, what about the pin 1 option, can I use this as a switchable power down - and of powered down will it allow the unamplified audio through it so I can at least hear it to know to turn the amplifier on? If it only turns the power off to the chip and the off chip won't alow anything through it , then this would be the same as what I did here; that is hook the power line of the MC34119 to a switch. Thanks for the time on this. Bruce
Audioguru, two questions: The chip disable pin. if this is utilized, will it allow the signal to still pass through even though it is not amplified? I have a switch installed now on the power supply of the MC34119, however, I seem to forget it is off, and when someone is calling me I can't hear them. I'd rather the audio be low then not present at all. Then when I want full sound effects and FRS amplification, I can then switch off the no 1 pin chip disable and she wil deliver the full volume. Is this possible? Is there any other IC that is comperable to the MC34119, since the MC34119 is no longer being made? I need to buy more. Bruce
Audioguru, The device needs to be able to use the sound effects even if I have the FRS off. That is why I just don't splice the MC34119 power off the FRS switch, because then I would need to turn the FRS on to also power the op amp for the sound effects. The op amp and FRS share the same power source at 4.5 volts, where the sound effects utilizes a reduced voltage shunted off the 4.5v with the two diodes to a bit over 3 volts (at full battery strength of course). This battery drain must be from the op amp because when the FRS is off, there is no power runing through it. And - the sound effects circuit board, when in it's original toy, did not drain the battery when not being used. Therefore it must be the op amp, which is direct wired to the batteries. Is there an op amp out there that has a low voltage auto turn off feature that is comparable in way of power requirements to the MC34119? There is absolutly no more room for yet another IC chip. Is there no way to put a switch in the power line of the op amp by itself? If it comes down to it, I will have to find a very small slide switch - that is acceptible to me, as I can turn on the op amp when I wish to use the sound effects and the radio and turn it off at the end of the day's usage. Is there nothing I can put in line somewhere that will turn on the op amp's power when the signal voltage going into pin 4 reaches over a certain threshold, and then turns back off when the voltage drops below this threshold? I assume that the voltage from the two units feeding into pin 4 is at line level now that we have kocked it down with your modiciations, but does this level not gain in voltage somewhat when the audio signal is being fed into pin 4? Bruce
Audioguru, Here is the schematic again. The diaphram switches close the positive supply circuit. I jumped wires off the pads of the diaphram switch to the tac switches in my build, as I need them so I don't want to replace the tac switches. Do you need me to check what the voltage is at the speaker input at the op amp before the capacitor and resistor at idle and then when the sound effect is activated to see what the voltage difference is? Remember that the sound effects circuit is powered of the 4.5 volt batteries knocked down to a bit over 3 volts through two diodes in series. Bruce
Audioguru, The pads for the diaphrams are indicated in my schematic I drew earlier in this thread. Bruce
Audioguru, Where woud you put it? I use two of the sound effects of the three that came in this unit - there are two diaphram switches. Would my regularly installed switches still activate the souinds as needed? but this capacitor and resistor would switch on when power met it, and switch off when power decreased to it - is that the Idea? I posted the schamtic I drew for the sound effects unit. Can you tell from that? Otherwise, how do I check - put the tester on the speaker out to the difference in voltage whne operating and not? Bruce
The FRS radio obviousley has an off/on switch, but the sound effects chip does not. On the original toy it came in there was no on/off switch, the sound effect is activated when a diaphram switch is hit wich completes the circuit - but it is momentary. You hit it once and the sound effect plays through to it's end, and then resets when the diaphram is hit again. Holding the switch closed causes the sound effect to play in a continual loop. I guess that meas the original toy circuit is always hot. Bruce
Audioguru, I have a problem with my first communicator build which we used that MC34119 amp in. Something is sucking the batteries of power even when it is turned off. I'll leave it on the desk after using the sound effects for a few days, and the batteries are dying. Any ideas? Bruce
O.K. I do have some .022uf and .047uf capacitors, so I'll go that route. Thanks, Bruce
Audioguru, You threw in a few wrenches on me here. I see the original 3.3k resistor is changed to a 12k and an extra 4.7k is added with a "68nf" - what is that a capacitor? Do I have to use an nf capacitor, becuase those have to be ordered. I looked and see a 68nf is the same as a .068uf. Again, not commonly found. What happens if I use a .047uf? I'll have to see if I can dig up those values of resistor. The speaker may not like low frequencies, but I'll try it. Thanks, Bruce
Audioguru, With this MC34119 circuit, can you tell me how to add (if possible) the proper components to boost the low end audio like what can be done with the LM386? Thanks, Bruce
You stated: "The LM386 has a 50k resistor at its input to ground inside the IC. The 1M resistor makes a voltage divider with the 50k resistance, attenuating the 3v p-p signal from the effects circuit to 150mV p-p. Then the LM386 amplifies it 20 times to 3V." So I did O.K. then? As fro the LED, I'll put the tester on the power leg of the LM386 and find the voltage and then put in a resistor as specified on one of those LED web sites to match the required LED's forward voltage. Bruce
Audioguru, Oh yes, I see, and also, the amplification would not work with the FRS turned off. O.K. scratch that idea. Do you think I could run an LED off of the power pin of the onboard LM386, which I need to turn on when the FRS is turned on? And, do you see any issues with me having to use the 1m resistor in this LM386 curcuit that I built for the sound effects? 1m is a long way from 10k, but it was the only one that I found that kept the unit from distorting. Bruce
I don't need a volume control I just want to amplify the sound effects based on the value of the resistor, and since this FRS already has an onboard LM386, perhaps I could tap into that and in effect feed both of these circuits into one speaker like the last build I did. Why shoudl I build a new LM386 amp, when there is already one there for me to use right? Would this work? Bruce
I am creating a second FRS communicator. I am using the same toy hacked sound effects circuit as specified earlier - (I have a few of them of course, the first FRS works fine but the batteries go fast). I wired the + speaker output to a 10 ohm reistor then to the - output as you had me do before. The negative speaker is then fed to the .22, then the 1m resistor then the LM386. The resistor was the only value I could find that would keep the LM386 from distorting the speaker. Generally the LM386 schematics show to us a 10k, but that created nothing but distortion. I did not add the capacitor between 1 and 8 either so it is minimal volume. If I were to tap into the FRS onboard LM386, I would not need volume control for the sound effects. Should I try it? Bruce
Audioguru, I created an amp with the LM386 as you stated. It seems to work fine. I used a schematic you drew up on another thread from last year. However, after looking at this 6v powered new FRS I am using, there is a LM386 clearly marked as such in use on the circuit board already. What would happen if I connected the sound effects circuit to the input of the onboard LM386? Sound effect out to a .22 uf capacitor, then the relevant resistor (I used a 1 meg ohm this time to keep the effect from distorting) then to the input pin of the IC on the FRS. Would it work? I assume I would be bypassing the onboard digital FRS volume control with this also. Bruce
I went shopping today and bought four Zener diodes like I used for this other build, and will test them out tonight or this weekend,. Thanks, Bruce
Can you give me a bit more on the diodes. You gave me the way to hook up two diodes earlier in this thread to get 3v from 4.5. So now I do this procedure twice using four diodes? Bruce
Audioguru, This issue was my error. I opened the comm back up, and I had the 10uf capacitor backwards which caused chaos with the batteries. After resolving this issue, the volume pot works, but there does seem to be some damage in the middle of the sweep which was my mistake also. Out of curiosity, will this amplifier schematic you provided work "as is" with 6 volts run into it instead of 4.5, as I will need to do it with my next build? And, is there any quick and simple way to knock the 6 volts down to 3 to power the sound effects? two sets of diodes perhaps instead of one, or a voltage split? Regards, Bruce
Audioguru, I have no idea where the amp is. The schematic I posted is off the FCC web page and is the original submitted drawing for this model radio. They do state that the production models may differ from the submitted drawing to some extent. Bruce
O.K. here is the jack. Right now I have the wire to the amplifier fed off the head of the jack. Perhaps I should have it attached to the shaft? and that is why I don't have volume control? Bruce
O.K. so I was wrong and the headphone output which I am using is amplified. How do I fix my problem do you think? Maybe tonight I will snap an image of the internals of that headphone jack. I noticed when I was breadboarding it, the MC34119 circuit worked with the FRS on either pin of barrel of the jack I plugged in it. The jack does not look like the schematic. When pushing the jack in, both contacts move off of posts inside. Perhaps I have the output to the MC34119 linked off the wrong end of the jack. Thanks, Bruce
Audioguru, This is the issue I saw coming. Remember one of my initial posts on this subject? I saw a red flag but I thought it was just my musings of a novice. Perhaps I may be right on this one. The FRS volume is, for lack of a better term, "double cut". The original volume pot controls the audio signal at line level (I assume), and when the volume is all the way up, the pot is letting through probably what .3 volts? (for full line level), and when reducing the volume by turning the thumbwheel, that voltage is reduced to even less (and there isn't much to reduce). Since I have tapped off the headphone jack, instead of the speaker - am I correct in assuming that I have effectively bypassed the on board audio amplifier? With an unamplified line level out of the FRS, "cut again" by the 3.3k resistor in the new circuit we created, I will only get volume when the FRS pot is at full volume allowing the full signal to pass, because any less then full volume is such a small amount of signal, it is inaudible. Is this summation correct? and if so, do I really need the 3.3k resistor on the FRS end of the new amplifier circuit, since the original onboard volume pot is already supplying line level? I measured the volume pot some time back and I think it is 10k rated already. Bruce
