Buddi
7 -
Everything posted by Buddi
That may be the reason then...thx for showing it to me... Anyway as I mentioned it has some issues still... 1. Very visible flickering once the bulb is given the full power 2. Limited dimming range: The bulb dims...but I expect it to dim much more when I vary the resistance... I'm trying to find a way control the level of gate
that is something that i also couldnt understand... but it worked... ??? the circuit didnt work until i decided to put 2 vaiable resistors for both R5 and R6 just to test with different values... And now I have left the circuit as that... yep, it cannot make any different theoritically, but it did... Buddi
Guys, I think I foud something...I did some analysis with the oscilloscope and found out that the cap. and the R6, R5 resistors that should determine the output does not work properly... then i did a slight modification by interchanging the R5 and R6 and now the dimmer is working... :D Now two small things to sort out... 1. When I vary the variable resistor the illuminance is increaesd and right at the very end there is a slight dimming that occurs after the bulb has reached the full illuminance... 2. There is a slight flickering of the output when put to the full power What do you guys think of these...??? Buddi
thx... so what do you guys think...? I tried with different resistor and cap values, but didnt work...
Thnx very much... This is one idea that I intend to use as a benchmark. http://johboh.csbnet.se/____BINBOSFAX001.reedbusiness.com__c$__Program%20Files__RightFax__Gateway__IN__A628c412e-b8cf-4efe-a2bd-d6c8b9a99ada.TIF There is some extensive heat dissipation as you have mentioned... and it seems there is some problem with gate triggering and the bulb flickers instead of steady dimming...I used IRF 540 MOSFET.... Buddi
Hi, I'm working on a project where I'm desigining an AC dimmer (230V/1000W) with Electro magnetic compatibility. My idea is to involve IGBTs or MOSFETs instead of more conventional triacs... Do you think that this would be a good idea? If you have prior experiences please share... Regds, Buddi
