oddabe83
4 -
oddabe83's Achievements
Help! Connecting power supply to small load/solenoid
oddabe83 replied to oddabe83's topic in Electronic Projects Design/Ideas
Hi, I suspect it might short circuit as the coil is really just wires coiled up into a lump. Are inductors actually solenoids? Inductors actually shorts themselves if connected to a DC supply right? What would you suggest to prevent the high voltage? Will a diode help? -
Do u mean if i provide the correct amperage, the circuit will not short itself? Is it true that solenoids in a DC circuit is actually a short circuit? -
Hi! I bought this solenoid from an electronics hobby shop. It consists of just coils of wire, with a metal rod in between, such that when current is passed thru the solenoid, magnetic field is created and the rod "sucks" inwards. The problem is, the solenoid is connected by a DC supply. As soon as it is connected, even though the rod did suck inwards, the whole circuit shorts itself. The solenoid's resistance is only 3.6ohms. As such, if I put a resistor in series with it, little voltage is passed thru it (it needs at least 6V), and it wun work. Can anyone kindly draw me a circuit that alleviate such situation? I need 6V to pass across the solenoid, and as little current as possible.. Thanks in advance!
