MPapps
7 -
MPapps's Achievements
Turning a 7805 on/off with a Push to Make Switch
MPapps replied to MPapps's topic in Power Electronics
ok thanks, what modifications would i have to make to run off 13.4v? Thanks Again. -
Hi, I must admit i'm a little confused by what you said, my output of my 7805 will by required to supply current upto the 1.5A, so what circuit solution can i use for that? Thanks. -
Looking at the datasheet do i not need a transistor with a higher current rating as my Voltage Reg could be drawing as much a 1A? Thanks -
Hi, Thanks for you help, but i'm a little confused isnt a 2N4401 a NPN Transistor and you have it shown as a PNP? Thanks. -
Would it work by using BJTs like this? Thanks for your help -
Hi All, I am trying to design a circuit to do the following: Use a Momentary Push To Make Switch to toggle the input of a 7805 on/off The 7805 is supplied by regulated 12v so i need a circuit that switches its output between 0v and 12v using a Momentary Switch. I was hoping to find a design or at least a starting point somewhere but have had no luck so far. Any Suggestions / ideas would be great. Thanks :)
