65 -
Calendar
Everything posted by Steve_hi
Hi http://www.tutorgig.com/ed/PH_meter
Hi M.JAWAD What do you mean by report what are you looking for :)
I didn't know I could! I will try to figure out how, get it ready and do it. Thanks :)
A suggestion for new projects to whoever is responsible for this department!! A pH-METER Thanks
help me please about(ph meter)
Steve_hi replied to M.JAWAD's topic in Electronic Projects Design/Ideas
Hi M. Check with cole parmer they sell many types of probes at different prices it will be the largest expense of your project You can also bid on probes at Labx.com but be careful many sellers take your money but dont send the product. http://www.drsfostersmith.com/Product/Prod_Display.cfm?pcatid=4496&Ntt=ph%20probes&Ntk=All&Ntx=mode+matchallpartial&Np=1&N=2004&Nty=1 Check this site for info concerning ph probes http://www.omega.com/techref/ph-3.html Here is another very good site http://wind.prohosting.com/prakaash/ph/ph.htm Please let me know how your project turns out :) -
Heres one more -
Hi I hope theses are useful for you if not I have more -
Hi Master_Ianick There is also another program called stripboard magic that you might like to look at. It can be downloaded from the internet and it too is free :) Thanks to Ante You can download SBM from here: http://web.onetel.net.uk/~stuorguk/StripboardMagic.zip
need a program to simulate in electronics
Steve_hi replied to walid's topic in Electronics chit chat
http://www.linear.com/designtools/software/switchercad.jsp -
Nub needing help with questions
Steve_hi replied to Bulldog's topic in Electronic Projects Design/Ideas
You could get tube like that from a machine shop or mill supply store reamers and drills come in tubes like that you could cut a piece of strip board the size you need you can buy it from mouser futurlec or digi-key -
This is what I refer to when I say Stipboard Thanks guys
As you have stated with disposable electronic products and the global economy such as it is I would think one would need to be exceptional to get ahead in the electronics field probably better just to have it as a hobby I hope I'm not being too pessimistic about this
Hi Philipf I made both the stethoscopes the one with the 5 741 op-amps doesnt work at all but the stehoscope2 by Audioguru works really well. I took it to class and all the students liked it. It is much easier to listen to a heart beat than with an accoustic stethoscope
Hi Herman I hope you don't mean that you have to marry her to get a schematic!!! LOL ;D
Thany you Hans for the reply I'll check it out :)
Are there anywhere to request free photovoltaic cell????
Steve_hi replied to bbmak's topic in Datasheet/Parts requests
Very little in life is free you will have to work at getting them. A company letter head and a projected sales volume will probably get them interested in giving you some samples but your presentation will have to look professional. Good luck ;) http://www.photowatt.com Send Email to Photowatt International S.A. http://www.npowercanada.com Send Email to Npower Energies http://www.china-solarpower.com/sdp/110301/4/main-1000013.html Send Email to Shenzhen Xinhonghua Solar-Energy Co., Ltd (Representative:Angel) -
Water absorbs infrared light so water will decrease the brightness of the infrared signal.
If all you want to do is test them then just use a 12v car battery you will not have to do anything
Thank you very much for the help Audioguru I will order the parts this weekend and should have them in about 3 weeks from futurlec they have very good prices but slower than the second coming. bye
Is there a new schematic with a parts list for an improved version?
Hi Audioguru I,m going to make the faulty one first and get you to walk me through the tests of it then after it fries I'll make it properly.......................I hope ;)
Hi guys This is a very entertaining thread, so much so that I, as a beginner will now try to make this power supply I hope I can get past putting the first part on a strip board keep the debate going gentlemen it's better than T.V ;D
Hi I made an ECG and when I do a continuity test for the positive battery terminal and the # 8 pins of the TL072's i have continuity, but not on the center tap of the 2 9 v batteries, and when I check for continuity of the negative terminal and the number 4 pins of the op amps ihave continuity but I also have continuity with the negatve battery and the center tap of the 2 batteries, is that supposed to be like that is ground and negative the same?
