elix
50 -
Calendar
Everything posted by elix
what is a PUT? ???
is clamper another word for thermal switch? never heard of it before.
:D even though it works perfectly in the sim i have to make something of my own creation, else i'm not learning so i'm going to try it now with a active current sink since i can use the gate voltage swing to my advantage. you've won this round *shakes fist* ;D
i'll try and figure out a way to lower the impendance. some heat wasted is ok, i only need 1 watt from each channel and the mosfet bias will come from the op-amp. question: to lower the impendance don't i have to raise the current or can it be done a simple circuit, i'm trying to keep a class a single ended mosfet. (gotta learn :P)
i am starting over ;D btw that current source was working right then i pulled a resistor live and now i have two holes in my breadboard and two cracked fets :-[ good thing i have more :)
your right, i have it hooked up right on the board but wrong in the schematic, funny thing it works fine in the sim then when i put it right i got a jagged wave!!! so i got rid of the 317 and put a more flexable current regulator in, tell me what you think. still have to build this one but i must go to bed.
here are the node voltages, i have a vom hooked up to the bottom of r8 and the voltage is hardly moving but something is giving me crazy bass from this regge song, sounds great! 6 ohm load, r1 is 4 ohms, have on a small lead acid battery. i had it as shown and worked great. clean sine waves to 5Mhz, no artifacts to 15Mhz which is the max i can test to. the more current i have the less voltage swing i need?
"Your OP37A opamp has a voltage gain of 19k/10k= 1.9 with a low impedance source, and a voltage gain of 19k/(4.7k + 10k)= 1.3 without an input. But the OP37A opamp is de-compensated and is unstable with a voltage gain of less than 5. It will oscillate." does it matter since i'm not using a split supply?
i've made some changes again, the amp did oscillate but because the mosfet was actting as an anttena in the low Mhz. new mosfet, some changes. so far no problems from the op-amp, will look at the data sheet.
it's not really supposed to have voltage gain, it's a current amp :) rev1.1: the op-amp is opa37
i'll be making some changes, keep the comments comming. :D
URL=http://imageshack.us] not bad considering i used whatever was laying around, tell me how i can improve it, spacificly how can i get the mosfet in the feedback loop?
The relationship of Amplifier vs Power vs Frequency
elix replied to SHEN PEI's topic in Theory articles
it depends on the load. -
hooked it up wrong :D
on the data sheet it says you can make a current regulator by just putting a resistor on the adj and out pins 1.25/R = current out, why is it pulling 1.5A with a 100 ohm resistor?
maybe back emf is destroying your regulators?
thanks audioguru, i'll now proccede to made an amp.
"IRFZ44 has a minimum drain current of 31A if its gate voltage is 10V" so does it matter what the drain voltage is?
i'll answer one, Vt is the voltage threshold, should be 0 to start off with but if you reverse bias the gate current flows backwards through it :o
using split supplys if i keep the gate at 4 volts above drain it saturates, when gate equals 0~4 volts above drain it stays in linear mode (corresponds to Vgs for irfz44, which is what i'm testing). Id=2k[{(Vgs-Vt)Vds-Vds^2}/2] is how you calculate drain current in linear mode but here's my questions: Vt should be what? is Vds the drop between drain and source? it shows up as one diode drop if so. how do you figure out what k is?
gate V to I is almost 1:1, so what is G used for?
ok i have 3 points gate voltage current gain Vd 4.6 2ma 1.8 5.2 13ma 2.2 5.6 25ma 2.45
ok, i think i understand mosfets when they are in saturation mode but i'm having trouble figuring how to calculate gate voltage (Vgs) to drain current (Id) using G(transconductance ratio). in the schematic i just left generic values, i have a led in the place of r2 and i'm making a plot, but for now this is good enough, bed time ;)
