ben23
28 -
ben23's Achievements
would the KEMO #M40 pre-amplifier module be ok to amplify a guitar output to line level so i can play my guitar thru a normal amplifier when I dont have access to a proper guitar amp. here is the link for it: http://www.jaycar.com.au/productView.asp?ID=AA0220&CATID=&keywords=amplifier&SPECIAL=&form=KEYWORD&ProdCodeOnly=&Keyword1=&Keyword2=&pageNumber=&priceMin=&priceMax=&SUBCATID= and this is how i figured i should wire it, the guitar input being a 1/4" jack and the outputs being dual RCA's
yeah a transistor type of switch would be good but i too have no idea how to make one, a transistor switch is a solid state relay basically. rating wouldnt need to be anything high, as the start up current is only momentary and very small (<200mA)
AT PC power supply only putting out 10V between 12+ and GND
ben23 replied to ben23's topic in Power Electronics
yeah theres nuthing on the 5V rails, ill have to try that, i have a little 12v pilot light, ill measure the resistance and see if it will be ok, that way i can see if the PSU is on as well. there is an orange "power good" wire, should i ground that or power that or anything, maybe so the PSU thinks the "power's good" or is that so the MB knows that the power's stable if i used the 12+ and 12- rails instead of 12+ and ground would it get more power? -
ok first your going to need it to work like this phone rings - relay closes - computer starts up you hang up - relay opens - computer keeps on running to turn off phone rings - relay closes - computer begins to shut down (as long as you have configured the Power settings in Control Panel to do so) you hang up - relay opens - computer proceeds to shut down you observe to see whether you can access the computer anymore, if you cant, your successful, if you can, you need to ring, and let it ring until you lose connection, which will do the same thing as holding the button on the front of the computer until it turns off. you will need a TTL type relay (which work on tiny voltages) to switch the green wire from the computer power supply (turn-on) and one of the black wires from the computer power supply (ground) just splice into these two wires, just splice and solder and tape/heatshrink. I will have a look for a suitable relay and get back to you with the details. This is actually quite a good idea.
i have a old 220w computer psu, so old that its an AT, and was built in '94, im using it to power my 12w x 2 amp that usually is in my school bag with the speakers, but im sick of charging the battery all the time at home, so i rigged it up to this PSU, but i measured the voltage between 12v+ and ground, and i only had about 10.5, dropping to 10.4 when pushing it. with no load its at 10.6 should i just get a new PSU? or is there something I can do btw i hooked up the fan to the 12v supply but it couldnt be drawing that much, its only an 80mm fan. its a regulated switching supply (well i assume its regulated), so shouldnt it be at 12v exactly? btw I have 2 of the 12v+ twisted together and soldered to a wire going to the positive of my amp and 2 of the grounds twisted together soldered to a wire going to the negative, should i maybe just use one of each? or diodes? any help appreciated
i actually recommend a 3PDT, so that way you can switch the grounds and isolate the other inputs ground to avoid interference and/or ground loops.
Difference between rms and PMPO
ben23 replied to electronics_shamim's topic in Electronic Projects Design/Ideas
basically PMPO is bullshit RMS is what u should be looking at -
yeah i think ive just had bad luck with the PSU's, that 5+5+3.3 sounds pretty good actually, nice work Ante, cos that gives 13.3 like u said, but its not voltage that worries me, admittedly, it wasnt a 300w now i think of it, it was actually a small mini-ATX 80w power supply, with 2.7A on the 12v rail, and it was a cheap CD/tuner how many amps can u pull with the 5+5+3.3 setup safely? would a 300w psu be enough to power a small BOSS CD/Radio head unit, that is probably about 4 x 35w - obviously theoretically it could run 2, but im making room for heat dissipation and that so yeah, was thinkin of settin that up in my shed. set that up with 2 x 6 inch's inside and 2 outside the shed that would be all i would be running btw if u start to overload the PSU 12v rail, do they tend to start poppin capactors, or do they just fail? sorry to hijack the thread but its the same thing thanks ben and to Frank, the only concern is the small gauge of wire that will be connecting the amp (18 gauge) to the psu, unless, you modified the PCB and allowed it to fit 8 gauge straight from the PCB. i only recommend the battery as u will be able to run any amp you want and not have to worry bout blowing a PSU up and u will avoid having to control the volume around the PSU's amperage.
to put it simply, there needs to be a point of 0 volts i.e the neutral wire
ok first of all, how much does the amplifier draw in amps (the fuse rating is a good indicator of what it is) or check how many watts the amp it is. then divide the wattage by 12, you will get the amperage draw (this would obviously be at maximum volume) second of all, once you have found that, u will need to see how many amps you can draw from the 12 volt rails of your power supply. the equation 600/12 = 50A would not be right, as that 600w counts for the 5 and 3.3 volt rails, which will not be used here. on most PSU's there is a label which will tell you the amperage of the 12v rails, and as far as i know its per wire, so if it says something like "+12v = 8.2A" thats the maximum you can draw from each wire, hence the diodes, so they dont cancel each other out, once u have found the amperage, multiply that by the number of wires, noting that there must be the same amount of ground wires (must also have diodes) as there are power wires. third of all, a computer power supply isnt a very rugged source of power, an amplifier really needs a beefy source of around 13.8volts it will work, but it will not be very efficient, and will most likely be short-lived. when the power supply makes a sound reminiscent of a cap gun going off, you have blown the output capacitors and the power supply is pretty much finished. i have tried to use a 300w psu to power a small car radio (no cd or tape, just radio), it had a capacity of 8.2amps at 12v, but i still blew it! because they aren't solid enough. best bet is to get a small car battery (or even a 12v motorcycle battery), and a charger. or order a 20amp 13.8v power supply for AU$99.95 (works perfectly) from www.jaycar.com.au and that should have enough grunt to power any amplifier up to 300w. if you arent in australia it is ok, as you have 220V as we do (actually 240v but there is really no difference), just buy it, change the plug or use an adaptor, so there will be no problem with mains voltage. Warning: if you are intending on using a large 4 channel amplifier it really isnt worth the trouble, as any power supply capable of powering a large amp like that will be expensive, large, and heavy. you never know u may be able to power it, i just need to know the amplifiers power, the amperage of your PSU's 12v rail
what about using a hall-effect device, that could work, the ones used in car ignition systems
yer that was my first idea but i dont want the added weight of a battery and inverter, rather just have the engine, induction motor (alternator) and capacitor bank and have it wired to a standard power point
first of all, make sure of these few things - you have a quality power supply - your power cables are in good condition and are plugged in tight - you have a RCD = residual current device (safety switch) or a GFCI for americans whether it be at the switchboard of your house or as a plug adaptor DO NOT LOOK PAST THESE DEVICES THEY SAVE LIVES. - you have a reputable surge protector, as excessive surge current passing through a computer will do more than fry it, it will create excessive heat that can start a fire - you keep the computer clean of dust and all fans are working - you have good ventilation space around the computer - you turn the monitor OFF, not let it go into standby when not using the computer and that the monitor is free of dust personally i dont leave my computer on at night as there is no need, the only thing i leave on is my DSL modem (which i had to permanently fix on cos the switch broke and most modems dont have a switch anyway) but if you are going away for a length of time and the house is going to be empty, do what i do - UNPLUG THE LOT -ben
now i know i have the system thats in my school bag (the 12w x2), but i need one thats smaller, i have a small amp pcb from a pair of multimedia speakers. it has the usual tone and vol control pots on it, but, its made to run on 12v AC from the mains transformer, but right after where the power leads solder to the pcb, there are 4 diodes and a capacitor, me thinks that is a rectifier circuit. i tried running 12v DC (using the SLA battery from my bag system) into the amp and it sounded ok, but a bit distorted, if i tapped into the pcb AFTER the rectifier, and determined the polarity, it should be ok right? im on holidays at the moment, when i get back i will get pics of my bag system for my other post, and pics of this amp -ben
yeah i know what you mean, im not too fussed on SQ, it just has to relatively clear, not distorted and loud. Car speakers dont have a specific enclosure requirement, as they are usually mounted in car doors. i would use the box i have but the way i have built the bottom has been built around the existing speakers, plus im going to make the next one from scratch i use it at school to play music at lunchtime and that (got told by one teacher never to bring it again haha, but the rest love it, so f*** her!!! thanks ben
