ingram010
8 -
Recent Profile Visitors
ingram010's Achievements
Attached is a circuit diagram, it looks ok, I think! but it wont work. Can anyone suggest why it is not working. all the components are suitable for 500vdc Cheers
I work in the R&D department for an electrolytic capacitor company. I have been asked to develop a completely automated data logging system using an Agilent aquasition unit. I have to measure 8 high voltage capacitors simultaneously, these capacitors will be measured for internal pressure via a pressure transducer, internal temperature vie a thermocouple and leakage current, they will be kept in an oven a 95 degrees for the duration of the test. The capacitors are supplied 500vdc using a GENH750w power supply, they will be under test conditions for weeks even months. The capacitors may reach 70psi at different rates therefore I need to turn off the supply to those particular capacitors individually. So, I have 8 outputs from a labjack U3 that go high when then the capacitors reach 70 psi, the labjack is powered by a USB. The idea in my head is to use the output to some how switch a Transistor,MOSFET,N Channel,SPP02N60S5 to turn on and off the supply to each individual capacitor, possibly using an opt isolator. I am thinking that I need to lower the 500vdc to something that can safely supply the gate of the mosfet. Please, please can someone offer some suggestions? Thanks John
Hello, I am trying to switch 500vdc supply, I am using (Transistor,MOSFET,N Channel,SPP02N60S5) supplied buy RS. Problem - the 500v supply is on wether or not the gate has a supply. Attached is a sketchy schematic. Please, please can someone help? Many Thanks John
Hello all, I am having trouble creating a circuit that will switch a 500v DC supply on and off, I have tried but failed. I confess I don
