surajbarkale
256 -
Calendar
Everything posted by surajbarkale
Use CAM Processor to produce Postscript Files (.PS) of the layers you need. You can convert this file to any suitable graphics format you need. Personally I convert it to PDF so I don't run into problems
C, Assembly & VB whatever is appropriate for the task :)
It should be ok 'C' indicates commertial range & 'P'/'N' indicate package type (I believe P stands for Plastic & 'N' for ceramic). If you get hold of datasheet these differences will be mentioned.
SRAM Substitute : Address lines ??
surajbarkale replied to cyberfreak's topic in Electronics chit chat
You don't need the address/data lines in exact order. Your circuit will function normaly. I generally reversr the D0-D7 lines on a 8051 board because they are easier to route that way ;D -
Check your multimeter. If you are measuring DC voltage on AC range some multimeters display double the value (this was true with older analog ones). While measuring AC ripple put a 0.1uF cap in series with probes.
Okey so next time I should say it's a TRIAC without gate ;D Anyway, I have used BC547 with base removed in a light dimmer project instead of DIAC. The project is still working (Don't know how though ;D).
I hope this is what u want - http://www.kmitl.ac.th/~kswichit/LFrobot/LFrobot.htm try goolging with 'line folloer robot' for more such links :)
Regardless of other things, the energy stored in a capacitor is too less to charge the battery. You shall need capacitance in Kilo or Mega :o Farads to charge the battery ;D
DIAC is a 3 layer device N-P-N (take a transistor cut base lead & you get a cheap DIAC ;D). You can also view it as two zeners connected back to back. There was a topic about DIAC some days ago you can search this forum for details.
Check out CD4033 it has internal counter & 7 segment decoder. You can use 74hc244 to interface it with a bus. But the discrete logic makes it cumbursome to mux display lines (you need too many IC's). And eventually cost of all IC's will equal a microcontroller. ;D
The common base configuration works because collector can provide same current as emitter without caring for the load voltage. Indeed collector acts as a constant current source. You can not operate emitter this way so at the max you will get an attenuator. In fact you can view a voltage regulator as the backwards transistor. And i don't think it offers any gain ;D
Check http://www.sourceforge.net you may find something there. Off the topic also check http://humorix.org/ quite funny. ;D
SAW filters provide accurate filter characteristics which are not influenced by temperature. Also the tolerance from one filter to another is very small. If RC / RL filter is used in it's place it would be very difficult to tune it (forget about replacing it ;D). Check this out http://www.oki.com/en/otr/html/nf/otr-158-15-2.html
Check out Practicle Transistor Circuit Design & Analysis By - Willems E. Gerald (PS - I am a looser when it comes to spelling ;D ) If you can lay your hands on it. It is the best book to learn transistor design from. Of cource Basic Electronics by Malvino is also a good book but he explains design in very short manner. Better refer to it after you have read the first book.
There are three ways to control speed of DC motor - 1. Field Voltage control 2. Armature Voltage Control (PWM falls into this category) 3. Armature Current Control Please visit http://www.epanorama.net/links/motorcontrol.html#dc there is a much better explanation than what I can provide ;D
You need to measure two variables here - 1. Strength of signal 2. Direction of Signal You can feed a unique high frequency signal to the wire at one end so that the wire acts as antenna. And use a sensitive detector to pick up the signal. You shall need two antennas to check the direction. Same can be achieved by checking the magnetic field generated by wire using hall effect sensors. But I think you shall need insane amount of current through wire for this kind of tracking. ;D
new design need HELP !!!
surajbarkale replied to portalia's topic in Electronic Projects Design/Ideas
Ante, SCR's gate only serves to turn it on. Only way to turn off the SCR is to interrupt current flowing through it. And this is the requirement -
You can connect LCD panel to transducer (provided these are not supply lines) if output range of transducer matches input range of LCD. (On many industrial devices this may be 4mA - 20mA). You need some thereshold detector to turn on the relay.
Search the term 'Switch Debounce' & you will get hardware schmatic for it. As for the counting task check out http://www.ee.washington.edu/stores/DataSheets/cd4000/74c926.pdf but I fear it would turn out more expensive than PIC. P.S. Check out AVR or 89C2051/89C51 they are cheaper than PIC.
Correct hall effect switch usage
surajbarkale replied to rbrainard's topic in Electronic Projects Design/Ideas
100mV won't be sufficient to turn on the transistor. Check the specifications of sensor again. If possible post a datasheet or number. -
European applience in North America, question
surajbarkale replied to sasha_ca_ru's topic in Electronic Projects Design/Ideas
+-120AC dosen't makes it 240V but it is a 120V/Hz. '+' indicates Live & '-' indicates Neutral terminal. I think you shall need a transformer to switch down the voltage. & If you haven't blown up the appliance yet. Use a low value fuse to protect it ;D -
So do you basically need a phase corrector which would correct the phase of voltage despite of the changes in load? ???
my retro pvr .. or personal video recorder
surajbarkale replied to stevearama's topic in Electronic Projects Design/Ideas
Winamp provides a plugin support which is used to display info on LCD. If the program you use for recording & playback supports plugins, you can run a check on their forums for the necessary software.
