236 -
Everything posted by trigger
some low cost dimmer will use SCR + diac circuit...
I agree with Audioguru. Especially you don't know much on the circuit.
use STV5730 as OSD driver for analog video.
You can try using 74HC193, the binary up/down counter and cascade them to counter up to 50.
It is a technology trend in using different buses...... the newest have the higher data flow bandwidth and faster speed.
I do approx. the same as Audioguru...... hold my breath while soldering.... and I will not apply paste unless it is necessary..... More is...... I will blow away the fumes..... when it comes up......
why not layout yourself? 2 days is far more enough for this layout............ ::)
nice pictures..... Sasi. So how are their performance then?
Want to use LED Dot Matrix Board
trigger replied to masterleous's topic in Electronic Projects Design/Ideas
Like audioguru said, only one column will be considered at a time. At the same time, you can determine which LED in a row will lite. Each column will state on a very short period of time and loop. I think it is no more method to make the LED matrix lites as you decided. -
Give a try and use spybot:search and destroy to scan for checking spyware.... you will get more spyware that adaware doesn't show you...... Here is the website and it is freeware http://www.safer-networking.org/en/download/
you have to change the phone system..... building your own circuit is not efficient ... buy one!
How do I start off for a Robot
trigger replied to Sumit Saraogi's topic in Electronic Projects Design/Ideas
don't be kidding....... using Pentinum processor will drive you into nightmare......... unless you got an industrial control board based on intel CPU..... else... don't touch it........ and most MCU are sufficient to perform motor controls........ -
My veroboard sample will not as tidy as Audioguru does............ :P Good job Audioguru!!! I got to learn from you... ;D
compare die bonding on PCB and IC fabrication ??
I have changed my web surfing using firefox for 2 months.... so far no big problem except some required IE only webpages. And there is no problem in here. And I really found out that I am free of spyware (I am using spybot:search and destroy to scan) ..... Previously using IE will result at least 5 to 6 spyware installed after a week....
Cleaning the CCD sensor of a digital camera
trigger replied to Dido's topic in Electronics chit chat
Agree tp Ante..... Open the case may cause more dirt inside.... which may be a disaster..... -
robots is a combination of electronics, porgramming and mechanical monster..... :P What Kevin refer to is the program codes on the MCU to control the robots.
ISA is no longer commonly available in nowadays motherboard.... except some industrial mini size controller board and do not "visually" distinguish the bus .......... get yourself a manual of the motherboard..... it will clearly state what are these!
Help with simple RF switching application
trigger replied to smartsarath2003's topic in Electronic Projects Design/Ideas
For lamp switching, I suggest you to use diac+triac for switching on/off, where you can find many of such circuits in the topics of dimmer switch. So, is there any meanings on the serial port data? If yes, I think you may need MCU to interprete the serial signals at receiver side . For transmitter and receiver, I think you can find many circuit in this site and some hot topics within this forum. The system seems not so complicated, just what you need to do is step by step doing so.... and many experts here (except me :P ) will give you much help. -
If you have block diagram of the system, there is not much difficulties on building each of them. And what is the problems you are facing in using IR?? Is the lamp are AC supplied?? RF transmitter and receiver? Frequency? AM? FM? Distance? You have to clarify your mind on these questions (or more) in order build the system. Remember to build block by block. -
max2606 center frequency is adjusted by the external L... can vary from 45MHz to 650MHz
acrobat reader 7.0 can read ps file.... I found it some time ago
use ghostscript and ghostview to print ps file
