Sorry for the duplication also posted under datasheet help as well, just really stuck on this one: Hello folks hope someone may be able to help me out. I've inherited some older power supplies which have me baffled(no manualto boot). The supply is a EMI(now lambda) TCR80S13-1-0V DC supply 0-80V 0-13A, it's SCR regulated, I only want to use it as locally variable. The problem is I can't get the crazy thing the put out any volts on the output. It has 2 main posts and a 14 position terminal block with the following 1 + V 2+V Remote Sense 3 V Programming I 4 V Amp In 5 V Programming R 6 V programming R Com 7 -V Sense Remote 8 -V 9 I Programming I 10 I Amp In 11 I Programming R 12 - Shunt 13 Inverter Amp In 14 +Shunt Tried several jumpered configs on the strip but no luck, if anyone knows what I'm doing wrong help would be greatly appreciated
