94 -
Everything posted by karthikeid
hi some of the components are not presently available to me to build that circuit... but i have attached one more file can u provide me some suggestions on it... i am not able to attach the file here saying the dir is not writable here... so i have uploaded in rapidshare sorry for the inconvince. http://rapidshare.com/files/277282868/transmisso__fm.gif.html in this circuit 0.3uH is given how to wind the coil ???
hi what will be the range atleast 500m... ???
hi can u provide me some other circuit that will have a good range...
hi http://rapidshare.com/files/276652026/fm_transmitter.pdf.html check this circuit need some help building this one... ;D
hi in this circuit http://w1.859.telia.com/~u85920178/tx/bug5.htm just change 547 which is parallel to 2.7pf, into BF494 then it is working fine
hi why dont u do ur own pcb it is very simple process only. for one pcb it will cost very high...
hi i have powered it by a 9V battery only...
hi i have made this circuit http://w1.859.telia.com/~u85920178/tx/bug5.htm at one frequency it is working fine for a long distance but when i speak there is bzz noise nd not able to hear clearly, can u help me to overcome this problem ??? in this circuit i have used 10pf instead of 12pf....
can u tell me wheather this circuit works out well http://www.aaroncake.net/circuits/fmtrans.asp
hi i need a fm transmitter circuit that works properly, very urgent pls help me. ::)
hi using the PIR need a circuit that counts using a display when it detects. check this for pir http://en.wikipedia.org/wiki/Passive_infrared_sensor
hi for this circuit... http://www.electronics-lab.com/projects/power/003/index.html
hi what happen to the power supply forum topic was it been removed ???
hi simple application that can be implemented with using optocouplers??
hi pls help me with a simple circuit using optocoupler using PC814 or some ???other one
hi i am having only 10000uf/63V capacitor can i use it instead of 12000uf ???
i am using multisim 10 someone pls tell me how to add components to multisim and for the IC CD4022B ??? :(
