482 -
Days Won
25
Posts posted by HarryA
I picked up some LM317's today (1.5 amperes max.). Set the output to 7.0 volts and
connected to a brushed motor. The motor drew 0.68 amperes. The output voltage
dropped to 6.86 volts; the li-po battery output drop to 11.55 from 11.80 volts.
This is with no load on the motor; I need to get propeller on it. Someday I will
receive the ESC and can reverse the motor on the fly. :) -
Thanks. I replaced my diagram with the one from Motorola before seeing yours.
I have power transistors coming from my favorite store - ebay. ;) -
My "bright" idea is to use the mosfet to get more than the 1 ampere that the 8 volt regulator is rated at. I have a large 11.1v li-po battery for the main motor so I don't want to add another battery to get the 8 volts.
I wonder if one can put two or three regulators in parallel for more current?
This current is the power supply for the speed controller; it connects to the
receiver for the PWM. It is the brushed type used with rc cars so it can reverse
the motor for left and right control. -
Hello all,
I need to connect an 8 volt electronic speed control to an 11.1 battery.
I have an 8 volt regulator and a power mosfet. I have not worked with
mosfets before so I am puzzled on how to make the connections and
what values of resistors are required. Please take a look at my diagram.
Any advice would be appreciated.
This motor control is for the stern of a model blimp to control the direction
much like a helicopter's directional control.
see: -
Thanks guys. That's what I needed to know :)
I made a tester out off a 12 v brake light and
a 6 volt one ;) -
I have a new power supply that I would like to check before
installing into the computer. On bench testing it I get no
voltage at all. Is thid correct? I am thinking that perhaps
there is some type of interlock so you only get voltage
when it is installed?
thanks in advance.
TENS machines revisited
in Electronics chit chat
Posted
Hello from NE PA,
A question for you. How to TENS machines generate 40 to 60 volts
from say 4.2 volts without using a coil or transformer?
Pictured is a TENS circuit that is about 1.26 inches by 1 inch.
The battery is on the reverse side of the board.
thanks in advance,
HarryA
