3 -
MANOTRONIC's Achievements
"A technique used in advanced microprocessors where the microprocessor begins executing a second instruction before the first has been completed. That is, several instructions are in the pipeline simultaneously, each at a different processing stage. The pipeline is divided into segments and each segment can execute its operation concurrently with the other segments. When a segment completes an operation, it passes the result to the next segment in the pipeline and fetches the next operation from the preceding segment. The final results of each instruction emerge at the end of the pipeline in rapid succession. Although formerly a feature only of high-performance and RISC -based microprocessors, pipelining is now common in microprocessors used in personal computers. Intel's Pentium chip, for example, uses pipelining to execute as many as six instructions simultaneously." This definition comes from www.webopedia.com ;)
Hi, what you need is a 555 timer ic, in "non retriggerable" mode. If you "google"( 8)) with the words "555 timer" you'll find about 54.000 results :D.The http://www.williamson-labs.com/480_555.htm for example,looks good. Hope i have helped a bit. ::)
Try: http://website.lineone.net/~colin_mccord/Radio/Theory_AV/class_a_amplifier_design.htm If you search the site you may find more useful information.This guy looks good 8)
