jasonbenn
Members
  • Posts
    5
  • Joined
  • Last visited
jasonbenn's Achievements
Newbie
  1. I may not be able to help you. But, out of curiosity, do you mean using a GPS as a peripheral to a computer and with a program that you are making? Or, are you interested in locating where in the GPS circuit would be best to connect your own circuit to read satellite signals that have already been interpreted to an extent? Something else? Is the application something that you can share?
  2. Maybe a better way of asking the question would be what is the equation for E - the electric field, between point electrical contacts on a sheet. I mean a large sheet - up to two feet by two feet. This might be different from the sheets that I've begun to associate with resistors - small and thin. Is there one equation for different large sheets? What types of equations are there describing this situation? If there are different equations for different sheets, are there equations that relate E to properties of sheets - that are more descriptive than the name of the type of material composing the sheet?
  3. The electric field on a sheet between a source and a sink is curved - as well as what appears to be straight between the source and the sink. I am wondering how much the shape of these curves has to do with resistivity of the sheet, the direction and strength of any initial magnetic field within the sheet before the source and the sink were introduced, and what might be the cause of these curves. I'd like to know if the resistance between the source and the sink varies directly as a function of distance.
  4. What causes the electric field between a source and a sink on a sheet to be representable with curves? How much can the composition of the sheet contribute to how much this field is curved?
