16 -
tendi's Achievements
Can someone have either a power supply schematic or a service manual for this 29' philips tv, chassis L01.1A AC. The tv just went dead. Tendi.
Hi Floris, Thanks for your reply. I hope to receive the manual if/when you email it. As for your problem of flickering Led, the line output section is not running. So check the line transistor for shorts or leakage. Check also the flyback transformer for inter-turn shorts. Also check for cracks under the FBT. Hair-line cracks are common under heavy components like FBT. If all these are ok, then check the line drive from the jungle i.c. tb1226en, through to the line driver. Hope you succeed. My problem is that the screen appears blank but the OSD is displayed ok and the sound is ok. I used a datasheet for the tb1226en and I disconnected pin# 21 and shorted it to ground thru 1k resistor. A picture then appeared but the OSD dissappeared. I then left it like this until I get service manual. But I think it's the cpu. What do you think? Tendi..
SO, WHAT IS YOUR POINT MR ENGZEEZ? DO YOU HAVE THE MANUAL OR NOT? ???
PLEASE HELP WITH DATASHEET FOR M52309SP.. THANKS.
Does any one have the datasheet for the m52309sp and is it compatible with the m52777sp??
Can anyone please help me with a service manual for the jvc avn2043 tv? Tendi.
I need a schematic for this mini component hi-fi. Can any one help. Tendi [email protected]
i need a schematic for the tedelex 14" colour tv model T148. I do not know the chassis type. Tendi.
