brighteyes
4 -
brighteyes's Achievements
If someone sends me an offer I would certainly consider it lol The ability to open/close a relay based on input voltage with adjustable resistance to change the voltage permitted which will be 0v to 5v. Anyone want to take on the challenge? Would pay via Paypal etc :)
Thanks Alex and Hero999 :) I'll have a good look through the pdf's and come back to you sp thanks very much! We have a mechanical device that we want to switch off on 4th, 5th and 6th so basically the output is to open/close the circuit or simply drive a relay which I can place in between one of the circuit wires. Do you know of any suitable relays and if it would be possible to use a variable resistor to control the voltage range that is permitted? i.e. to permitt 3rd gear In fact do you know if I can buy the whole solution from somewhere lol
Guys Can anyone help with a small project on a motorbike Guys Was wondering if someone could help me with a small project. I'm after something that will allow me to control (open or close) an output based on an input voltage taken from a Gear Position sensor on a motorcycle (0v to 5v) i.e. neutal=0.5v, 1st=1.1v, 2nd=2v, 3rd=2.7v, 4th=3.5v, 5th=4.1v and 6th=4.7v) Otherwards turn on when voltage is between 0V and 3V and off up to 5V. (On for 1st, 2nd & 3rd and off on 4th, 5th and 6th) I want this to act as a circuit breaker with the ability to control on/off per gear and was planning to break a signal wire. Any idea's? Cheers Pete
