ziizoo
3 -
ziizoo's Achievements
Ok. Thks for your help..
please help me find the right software for this program... i make a project about speech recognition.. i use HM2007 chip for this project.. my project is to convert a voice to text... if anyone know about this project, please help me guys... :( URGENT!!! Thank You.. PROGRAM: define osc 20 DEFINE LCD_DREG PORTD 'LCD data port DEFINE LCD_DBIT 0 'LCD data starting bit 0 or 4 DEFINE LCD_RSREG PORTC 'LCD register select port DEFINE LCD_RSBIT 7 'LCD register select bit DEFINE LCD_EREG PORTC 'LCD enable port DEFINE LCD_EBIT 5 'LCD enable bit DEFINE LCD_RWREG PORTC 'LCD read/write port DEFINE LCD_RWBIT 6 'LCD read/write bit DEFINE LCD_BITS 8 'LCD bus size 4 or 8 DEFINE LCD_LINES 2 'Number lines on LCD DEFINE LCD_COMMANDUS 2000 'Command delay time in us DEFINE LCD_DATAUS 50 'Data delay time in us TRISD = %00000000 'Set port D as output TRISC = %00000000 'Set port C as output TRISB = %11111111 'Set port B as input low PORTC.6 'Set the R/W bit to low pause 1000 'wait until the LCD initializes SCAN: LCDOUT $FE,1 'clear LCD display IF PORTB.0=$0 AND PORTB.1=$0 AND PORTB.2=$0 AND PORTB.3=$0 AND PORTB.4=$0 AND PORTB.5=$0 AND PORTB.6=$0 AND PORTB.7=$0 THEN LCDOUT $FE.$C0, "plz train the HM" IF PORTB.0=$0 AND PORTB.1=$1 AND PORTB.2=$1 AND PORTB.3=$0 AND PORTB.4=$0 AND PORTB.5=$0 AND PORTB.6=$0 AND PORTB.7=$0 THEN LCDOUT $FE.$C0, "one" IF PORTB.0=$0 AND PORTB.1=$0 AND PORTB.2=$0 AND PORTB.3=$1 AND PORTB.4=$0 AND PORTB.5=$0 AND PORTB.6=$0 AND PORTB.7=$0 THEN LCDOUT $FE.$C0, "two" IF PORTB.0=$0 AND PORTB.1=$0 AND PORTB.2=$0 AND PORTB.3=$0 AND PORTB.4=$1 AND PORTB.5=$0 AND PORTB.6=$0 AND PORTB.7=$0 THEN LCDOUT $FE.$C0, "left" IF PORTB.0=$1 AND PORTB.1=$1 AND PORTB.2=$0 AND PORTB.3=$0 AND PORTB.4=$1 AND PORTB.5=$0 AND PORTB.6=$0 AND PORTB.7=$0 THEN LCDOUT $FE.$C0, "jump" IF PORTB.0=$0 AND PORTB.1=$0 AND PORTB.2=$1 AND PORTB.3=$0 AND PORTB.4=$1 AND PORTB.5=$0 AND PORTB.6=$0 AND PORTB.7=$0 THEN LCDOUT $FE.$C0, "gil" IF PORTB.0=$0 AND PORTB.1=$1 AND PORTB.2=$1 AND PORTB.3=$0 AND PORTB.4=$1 AND PORTB.5=$0 AND PORTB.6=$0 AND PORTB.7=$0 THEN LCDOUT $FE.$C0, "three" IF PORTB.0=$0 AND PORTB.1=$0 AND PORTB.2=$0 AND PORTB.3=$1 AND PORTB.4=$1 AND PORTB.5=$0 AND PORTB.6=$0 AND PORTB.7=$0 THEN LCDOUT $FE.$C0, "stop" IF PORTB.0=$0 AND PORTB.1=$1 AND PORTB.2=$0 AND PORTB.3=$0 AND PORTB.4=$0 AND PORTB.5=$1 AND PORTB.6=$0 AND PORTB.7=$0 THEN LCDOUT $FE.$C0, "text" IF PORTB.0=$0 AND PORTB.1=$0 AND PORTB.2=$1 AND PORTB.3=$0 AND PORTB.4=$0 AND PORTB.5=$1 AND PORTB.6=$0 AND PORTB.7=$0 THEN LCDOUT $FE.$C0, "point" IF PORTB.0=$1 AND PORTB.1=$0 AND PORTB.2=$0 AND PORTB.3=$1 AND PORTB.4=$0 AND PORTB.5=$1 AND PORTB.6=$0 AND PORTB.7=$0 THEN LCDOUT $FE.$C0, "socks" IF PORTB.0=$0 AND PORTB.1=$0 AND PORTB.2=$0 AND PORTB.3=$1 AND PORTB.4=$1 AND PORTB.5=$1 AND PORTB.6=$0 AND PORTB.7=$0 THEN LCDOUT $FE.$C0, "green" IF PORTB.0=$1 AND PORTB.1=$0 AND PORTB.2=$1 AND PORTB.3=$0 AND PORTB.4=$1 AND PORTB.5=$0 AND PORTB.6=$1 AND PORTB.7=$0 THEN LCDOUT $FE.$C0, "word too long" IF PORTB.0=$0 AND PORTB.1=$1 AND PORTB.2=$1 AND PORTB.3=$0 AND PORTB.4=$0 AND PORTB.5=$1 AND PORTB.6=$1 AND PORTB.7=$0 THEN LCDOUT $FE.$C0, "word too short" IF PORTB.0=$1 AND PORTB.1=$1 AND PORTB.2=$1 AND PORTB.3=$0 AND PORTB.4=$1 AND PORTB.5=$1 AND PORTB.6=$1 AND PORTB.7=$0 THEN LCDOUT $FE.$C0, "word no match" pause 1000 'delay for 1 second before scanning the next word GOTO SCAN END Moderator Edit: Added code tags. Removed block capitals from thread title.
