55 -
Calendar
Posts posted by ARUN CHOWDARY
please tell me are you designing a circuit or testing the resistor connections
the CE configuration amplifier is used as power amplifier but it not stable at high frequencies
you can change both current and voltage inthe ce configuration
if you want to increase the voltage gain you have to change configuration -
very nice
can any one give the information on simulation softwares
you can connect them in series or parallel but the number of leds to be placed is based on the input power given given to leds if the limit of leds placed exceeds then the light intensity will be low
on which topic did you want to do project
its very simple you will found two terminals of the speaker and i think your head phone have three or four wires
on the pin of the head phone you will find three layers
Remove the enamel coating on the terminals and connect you will get output -
you can build it by only stuying in the books
the links are
www.intel.com/design/mcs51
www.atmel.com
www.semiconductors.phillips.com
www.sci.siemens.com
www.dalsemi.com -
what did you have to monitor in the motor where does noise come inn the motor by applying lubricants only we reduce noise
nice
c programming by grootfried
programinnig in ANSI c by Bala Guruswamy
lets c by yeswanth singh kanetkar -
it will only happen when the polarity changed in the dc mortor
by using stepper motor you can do this
have you a nice day -
please post the picture link does not working to get the answer
have a nice day -
did want to make a remote control car which can move in front and back only or in all directions???????
you have to attach the circuit diagram with it to get better information
i have to know the power supply used in you country please post we will reply
did you mean
1 series voltage feed back
2 shunt voltage feed back
3 series current feedback
4 shunt current feedback -
if you want to repiar it or make a new one
we will surly help you ;) -
very simple in the usb there will be four connectors
1.voltage
2.data in
3.data out
4.ground
you can use the first and last pins for the charging -
scra are constructed with the semiconductor material silicon as it has large for bidden gap we can only rurn on it by increasing the voltage than the forward break over voltage as the gate current increases the forward current decreases ::)
project
Posted
it is better to do using micro controllers did you need any help in it
