OK i will try to help .!!!! as we know the Fermi level is a limit to the transfer of electrons from the valence band to the conduction band. so when the electron is below the Fermi level position then he will remain Valence electron band but when it is above the Fermi level position then he will be in the conduction band but if electron is located at the Fermi level position then he has the same chance to be in the conduction band / valence band. as we also know that the position of the Fermi level is very dependent of the doping elements were given at a time element that is type (electron majority carriers), the Fermi levels will be more toward the conduction band, the more doping is given, the more she approached conduction band. contrary to p-type to more clearly you can see the image that I attach source: microelectronics an integrated approach (international edition) I hope this answer can help you
