hotwaterwizard
2,022 -
Everything posted by hotwaterwizard
efficient 12v to 5v regulator chip.
hotwaterwizard replied to fever16's topic in Datasheet/Parts requests
Just add a Transistor that can handle the load. 1 To3 Style 2N3055 would handle it with a small heatsink. The Datasheet Has a circuit for the Job. LM78xx.pdf -
Ignition Coil Dirver problems
hotwaterwizard replied to fullyautomatic12's topic in High Voltage Stuff
Here is one that does not use a 555. -
Hi! Has anyone tried this great intercom circuit?
hotwaterwizard replied to Lakhan's topic in Electronics chit chat
Is that why I hear a humm like the old Tube Intercoms use to have? -
What you have there is a very special 50 ohm Temperature Sensor. The Vishay Website will tell you a Distributor Near you. Click Here for Distributor ETG50 Vishay http://www.vishay.com/brands/measurements_group/guide/500/lists/ts_list.htm ETG Sensors have a polyimide carrier for flexibility. It is available as an encapsulated gage ( Option E ) with exposed solder tabs ( Option W ) with integral printed-circuit terminals
Looked for an Hour without much luck. What is the model number and manufacture of the D-Link?
Here is an easier one. -
This is the Best I could do. 170DC_MARANTZ.pdf
1-Source Electronic Components 591-B Bicycle Path Port Jefferson Station, NY 11776-3421 Web
Even EBAY sells Capacitors that will do the job. LOT OF 1uF 16V AXIAL CAPS-LOOK!! Item number: 270020134485 http://cgi.ebay.com/LOT-OF-1uF-16V-AXIAL-CAPS-LOOK_W0QQitemZ270020134485QQihZ017QQcategoryZ4662QQssPageNameZWD1VQQrdZ1QQcmdZViewItem Mini Radial Electrolytic Capacitor ~ 1uF 50V (100) Item number: 170021781483 http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=170021781483&ru=http://search.ebay.com:80/170021781483_W0QQcatrefZC3QQfromZR2QQfviZ1 Non Polar Radial Electrolytic Capacitors 1uF 50V (25) Item number: 170012887414 http://cgi.ebay.com/Non-Polar-Radial-Electrolytic-Capacitors-1uF-50V-25_W0QQitemZ170012887414QQihZ007QQcategoryZ111603QQcmdZViewItem
Type this in "1uf 16v" At Mouser and you get about 450 options At Digikey you get about 165 options
Schematic for PS2 AC Adaptor SCPH-70100
hotwaterwizard replied to jomiservice's topic in Service Manuals
Here is all I have Playstation2_Repairguide.pdf -
Looks like I am out of luck here.
Which 2 components? Maybe I can look at mine and tell you. You know you can get a free adapter from SONY there was a Recall on that one. http://www.us.playstation.com/Adaptor http://www.techimo.com/newsapp/index.pl?photo=14800 -
So you want someone to just send you these parts? Here is what I have for you Free Datasheets. CA3161E BCD to Seven Segment Decoder/Driver CA3161E Datasheet http://www.ee.washington.edu/stores/DataSheets/linear/ca3161.pdf CA3161E=NTE2032 NTE2032 Datasheet http://www.nteinc.com/specs/2000to2099/pdf/nte2032.pdf CA3162E A/D Converters for 3-Digit Display CA3162E Datasheet http://www.ee.washington.edu/stores/DataSheets/linear/ca3162.pdf CA3162E=NTE2054 NTE2054 Datasheet http://www.nteinc.com/specs/2000to2099/pdf/nte2054.pdf ???
HP VL-609 Motherboard manual or any ideas?
hotwaterwizard replied to GreekPIC's topic in Service Manuals
I found this. Here is one for sale on Ebay Maybe you could Email this seller with a Question about it. http://cgi.ebay.com/HP-Vectra-Motherboard-VB-609_W0QQitemZ120019746570QQihZ002QQcategoryZ4615QQssPageNameZWDVWQQrdZ1QQcmdZViewItem Other Search Results http://www.gittigidiyor.com/php/urun.php?id=1814281 -
I have 100 in the TO3 Case Style.
Compare. Manufacturer Name = Panasonic Average Price = 8.5239 Description = N-Channel Enhancement MOSFET V(BR)DSS (V) = 900 V(BR)GSS (V) = 20 I(D) Abs. Drain Current (A) = 5.0 Absolute Max. Power Diss. (W) = 2.5 V(GS)th Max. (V) = 5 V(GS)th Min. (V) = 1 @(VDS) (V) (Test Condition) = 25 @I(D) (A) (Test Condition) = 1m I(DSS) Max. (A) = 100u @V(DS) (V) (Test Condition) = 640 @Temp (
2sk818 is the full Part NumberPart Number = 2SK818 Manufacturer Name = Panasonic Average Price = 8.5239 Description = N-Channel Enhancement MOSFET V(BR)DSS (V) = 800 V(BR)GSS (V) = 20 I(D) Abs. Drain Current (A) = 5.0 Absolute Max. Power Diss. (W) = 2.5 V(GS)th Max. (V) = 5 V(GS)th Min. (V) = 1 @(VDS) (V) (Test Condition) = 25 @I(D) (A) (Test Condition) = 1m I(DSS) Max. (A) = 100u @V(DS) (V) (Test Condition) = 640 @Temp (
Need SunPlus SPCA536A (PB111) Datasheet!
hotwaterwizard replied to mobile17's topic in Datasheet/Parts requests
I have been digging on this most of the morning. Here is what I found so far. SPCA536A SUNPLUS SPCA536A (PB111) http://www.servtec.eti.br/downloads/webcam/spca5xx.html http://mxhaard.free.fr/liensspca.html http://mxhaard.free.fr/spca5xx.html Cameras used in Aiptek Pocket DV3500 Pocket DV5100 Pocket DV5300 Concord 3045 Kowa Bs-888e Mustek DV4000 Other Info http://lists-archives.org/spca50x-devs/00553-spca508-spca50x_enable_exp_brightness-does-not-compile-fix-someone-knows-registers-for-spca536a-aiptek-dv-3500.html http://camerahacks.10.forumer.com/viewtopic.php?t=3038&sid=dc5fa683d5411f3251e7f08ebe63c646 http://www.cexx.org/dakota/sucr.htm This one Has the Schematic http://forum.easydigi.com/dispbbs.asp?boardID=86&ID=14177&page=1 CLICK HERE FOR LARGER VIEW OF PINOUT pmp_0614_H002.pdf -
UM uhhhhhhhhh How was I supposed to know that? Duuuuuuuu Make me feal dumb.
Hard to find I have SPCA533A http://mxhaard.free.fr/spca5xx.html http://mxhaard.free.fr/liensspca.html -
Audioguru, How can you come to that conclusion if he has not posted a Schematic Diagram of his circuit yet?
More KID-7404 is the Detector I think you have 2 emitters in your circuit! KIE means Knight Emitter KID means Knight Detector http://www.transcanadaelectronics.com/knight_lites_cat.phtml http://www.transcanadaelectronics.com/view_prd.phtml?cid=014 http://www.mainelectronics.com/leds.htm KIE7304-1P 5MM INFRA RED EMITTER LED KIE7305-1P 5MM INFRA RED EMITTER LED KID-7404 INFRA RED PHOTO DETECTOR http://www.transcanadaelectronics.com/view_prd.phtml?cid=015 Circuits http://home.cogeco.ca/~rpaisley4/AutoRev4.html
Looks like the part number is good with a Yahoo Search KIE-7304-1P KNIGHT KIE-7305-1P KNIGHT http://www.mainelectronics.com/leds.htm http://www.4starelectronics.com/catalog3/0354/0354-9.html http://www.rpelectronics.com/Default.asp?Main=/English/OnlineCat.asp?Menu=/English/Content/Categories/CatM_11.asp%26Detail=/English/Content/Divisions/Div_11_200.asp
Here is the Datasheet for TB1238BN requested by neckforx69 [attachment deleted by admin]
