hotwaterwizard
2,022 -
Calendar
Posts posted by hotwaterwizard
A Speaker don't care aslong as it gets audio it makes a sound.
You will be using all of them as power
Just Recycled Power.
Even better.
Are you sure it is not 7.68MHZ ?
Mouser has several in-stock
7.6MHz Crystals
http://www.mouser.com/search/Refine.aspx?Ne=1447464+254016&Ntt=*7.6*%2b*MHz*%2b*Crystal*&Msb=0&Mkw=7.6+MHz+Crystal&N=1323038
IN-STOCK ITEMS
Mouser Part #: 520-HCA768-20X IN-STOCK
Manufacturer Part #: ECS-76.8-20-1X 7.68
Manufacturer: ECS
Description: HC-49/U Microprocessor Crystals 7.68 MHZ 20pF
Mouser Part #: 695-CS20-768 IN-STOCK
Manufacturer Part #: CS20 7.680MABJ-UT
Manufacturer: Citizen
Description: CS20 SMD Crystals CS20 SMD Crystals 7.68 MHZ 18pF CERAMIC SMD
Datasheet
http://www.citizencrystal.com/images/pdf/ms-cs20.pdf
Mouser Part #: 520-HCU768-20X IN-STOCK
Manufacturer Part #: ECS-76.8-20-4X
Manufacturer: ECS
Description: HC-49/U-S Microprocessor Crystals 7.68 MHZ 20pF
NON-STOCK ITEMS
Mouser Part #: 695-HC49US-768-U
Manufacturer Part #: HC49US7.680MABJ-UB
Description: HC49US Radial Leaded Crystals HC49US Radial Leaded Crystals 7.680 MHz 18pF HC49S THROUGH HOLE
Datasheet
http://www.citizencrystal.com/images/pdf/ms-hc49us.pdf
Mouser Part #: 695-CM309S-768-U
Manufacturer Part #: CM309S7.680MABJ-UT
Description: CM309S SMD Crystals CM309S SMD Crystals 7.680 MHZ 18pF PLASTIC SMD
Datasheet
http://www.citizencrystal.com/images/pdf/ms-cm309s.pdf
Mouser Part #: 695-CSA309-768-U
Manufacturer Part #: CSA309 7.680MABJ-UB
Description: Crystals 7.680MHz
Datasheet
http://www.citizencrystal.com/images/pdf/ms-csa.pdf -
I did not find what you seak but, here are my search results.
LM15SGFNZ07 C60 datasheet or just the pinout
http://www.eio.com/public/lcd.2004/0581.html
Siemens A60. Its a 101x80 pixel display module, 4096 colors
on-glas controller is named DJ3N0091
http://www.elektronika.ba/forum/viewtopic.php?t=356&start=15&sid=c29570107f62f877bc75f2b65c992d9a
LM4900BG33G100SNY Datasheet
http://www.elektronika.ba/forum/uploadz/1136315308_100x33_lcd.pdf
http://www.handyersatzteilshop.de/a_Handy-Display_Ericsson_K750i__Display%2BSony%2BEricsson%2BK750i_280524_805130-869935272__.html
http://www.mobile-files.ru/forum/index.php -
other alternitives Vodca Beer and Pee
http://www.theregister.com/2005/08/15/pee-powered_battery/
http://www.theinquirer.net/default.aspx?article=15064
http://www.brighthand.com/default.asp?newsID=11697 -
Here is one from our Projects section.
http://www.electronics-lab.com/projects/test/019/index.html -
First off this should be in the Circuit Request Section
Check out these posts they will help you on your Quest.
http://www.electronics-lab.com/forum/index.php?topic=1486.msg8973#msg8973
http://www.electronics-lab.com/forum/index.php?topic=1467.msg8772#msg8772 -
Here is NSX-AV520
Does 10x mean Thanks?
or you could just use an LM323 Regulator 5 volts 3 amps
Just add a Transistor that can handle the load. 1 To3 Style 2N3055 would handle it with a small heatsink.
The Datasheet Has a circuit for the Job. -
There are Hundreds if not Thousands of sites with a Google search.
Here are just a few.
http://www.nutsvolts.com/PDF_Files/tesla.pdf
http://www.zephyrtechnology.com/TESLA_Technology_/body_tesla_technology_.html
http://205.243.100.155/frames/build1.html
http://users.tkk.fi/~jwagner/tesla/tc-plans.htm
http://www.amasci.com/tesla/tesla.html
http://www.wordiq.com/definition/Tesla_Coil
http://www.richieburnett.co.uk/parts.html#schematic
http://www.kronjaeger.com/hv/hv/src/tesla/index.html
http://www.scopeboy.com/tesla/
http://users.tm.net/lapointe/TeslaMain.htm
http://a.webring.com/hub?ring=hvr;hubview=y
http://www.scopeboy.com/tesla/index.html
http://www.electronixandmore.com/tesla/1.html -
What you have there is a very special 50 ohm Temperature Sensor.
The Vishay Website will tell you a Distributor Near you. Click Here for Distributor
ETG50 Vishay
http://www.vishay.com/brands/measurements_group/guide/500/lists/ts_list.htm
ETG Sensors have a polyimide carrier for flexibility.
It is available as an encapsulated gage
( Option E ) with exposed solder tabs
( Option W ) with integral printed-circuit terminals -
Looked for an Hour without much luck. What is the model number and manufacture of the D-Link?
This is the Best I could do.
1-Source Electronic Components
591-B Bicycle Path
Port Jefferson Station, NY 11776-3421
Web
Help!!! I feel like I don't know what I'm doing
in Electronics chit chat
Posted
You probably need to know about Lighting and Audio Equipment in a Theater Atmosphere.
