hotwaterwizard
2,022 -
Everything posted by hotwaterwizard
Transistor datasheets with collector curves
hotwaterwizard replied to blacksheep's topic in Datasheet/Parts requests
paste the datashet if u know
hotwaterwizard replied to arsal_uet's topic in Datasheet/Parts requests
7555 sounds like a timer icm7555.pdf -
plz paste these sheets if u can
2sA683 http://www.ortodoxism.ro/datasheets/panasonic/SJC00001BED.pdf 4614 http://www.microsemi.com/datasheets/SA5-27.PDF 723 http://cache.national.com/ds/LM/LM723.pdf 2N3055 http://www.onsemi.com/pub/Collateral/2N3055-D.PDF 2sD313 http://www.cj-elec.com/ebusiness/product_images/b/cn_b_2_1093.pdf http://www.ortodoxism.ro/datasheets/WINGS/2SD313.pdf http://www.dccomponents.com/products/Transistors/Bipolar/TO-220/2sd313.pdf H1061 http://www.pmccomponents.com/data/TR/H1061.PDF -
Why women can't be Mechanics.
By the way I don't work in that Factory anymore. It payed only $10 an hour. I was a machinist (so to speak). I drilled holes, grinded parts ,used the Milling machine, Metal benders, Metal Punches (that shook the ground when the punch came down), metal lathe, large drill press, etc. then assembly. I had no part in the design. I was a general laborer, that just did as I was told. I work back at my old job now making over twice that much money. I am a Service Tech
GANG-OPERATED DISCONNECTS Gang-operated disconnects are used where more than one phase of a circuit must be opened simultaneously. The most common gang-operated disconnect switches are the air-brake type manufactured in 200-, 300-, and 400-ampere ratings in all voltage classes from 5,000 volts up. They are used at substations, switching structures, and on the lines for energizing and de-energizing transformer banks and other apparatus. They are also used for sectionalizing. Although they can be motor-operated, they are more commonly provided with a switch handle for hand operation. This type of switch is ideal because it lends itself to operation from the ground, often permitting service to be restored to sections of the network without pole climbing. http://www.globalsecurity.org/military/library/policy/army/fm/5-424/chap7.htm
Believe it or not the Earth is the 4th wire. That is why they call it Ground. Read more about it here. http://www.seas.upenn.edu/ese/rca/instruments/misctutorials/Ground/grd.html Take a look at his site. http://en.wikipedia.org/wiki/Electric_power_transmission And this one. http://www.wipo.int/cgi-pct/guest/getbykey5?KEY=01/69758.010920&ELEMENT_SET=DECL Here is OSHA's Definitions for Ground. http://www.osha.gov/SLTC/etools/electric_power/glossary.html Ground: A large conducting body (such as the earth) used as a common return for an electric circuit and as an arbitrary zero of potential. Grounded, effectively: Intentionally connected to earth through a ground connection or connections of sufficiently low impedance and having sufficient current-carrying capacity to prevent the buildup of voltages that may result in undue hazards to connect equipment or to persons. Grounded Conductor: A system or circuit conductor that is intentionally grounded, usually gray or white in color. Grounding Conductor: A conductor used to connect metal equipment enclosures and/or the system grounded conductor to a grounding electrode, such as the ground wire run to the water pipe at a service; also may be a bare or insulated conductor used to ground motor frames, panel boxes, and other metal equipment enclosures used throughout electrical systems. In most conduit systems, the conduit is used as the ground conductor.
I found a Datasheet on Woman. LOL
Here is the Datasheet tl074.pdf
UPC1204C Datasheet Pinout Schematic anything. Rec/Playback IC 16 pin (NEC)
CM5943 Search Results 2N5943=(CM5943) ECG77 = MM8002 = 2N5943 = PT5943 = PT4610 ECG278 = 2N5943 = 2SC1199 Part Number = 2N5943 Manufacturer Name = Various Average Price = 8.55834 Description = Bipolar NPN UHF-Microwave Transisitor V(BR)CEO (V) = 30 V(BR)CBO (V) = 40 I© Abs.(A) Collector Current = 400m Absolute Max. Power Diss. (W) = 1.0 I(CBO) Max. (A) = 10u @V(CBO) (V) (Test Condition) = 15 h(FE) Min. Static Current Gain = 25 h(FE) Max. Current gain. = 300 @I© (A) (Test Condition) = 50m @V(CE) (V) (Test Condition) = 15 f(T) Min. (Hz) Transition Freq = 1.0G @I© (A) (Test Condition) = 25m @V(CE) (V) (Test Condition) = 15 C(obo) (Max) (F) = 2.5p @Freq. (Hz) (Test Condition) = 1.0M Package = TO-39 Military = N http://www.advancedsemiconductor.com/pdf/2n5943.pdf http://members.tripod.com/~Malzev/comp/2n5943.htm http://www.nteinc.com/specs/10to99/pdf/nte77.pdf http://www.nteinc.com/specs/200to299/pdf/nte278.pdf
1)CM5943 http://www.chipcatalog.com/Datasheet/AF92F0582870E114E21B87688F1AD598.htm 2)2N4960 http://www.nteinc.com/specs/100to199/pdf/nte128.pdf 3)2N3839 http://www.nteinc.com/specs/300to399/pdf/nte316.pdf
ARRRRRRRR
http://www.lasermotion.com/StepMotor.html one of many Search Google with 50oz inch torque
Can't find anything on this IC
Understanding test conditions in any Datasheet
hotwaterwizard replied to shekhar_dandya's topic in Datasheet/Parts requests
Yes, you got it. The Test circuit would be a great starting point but, pay attention to the maximum allowed voltages etc. Alot of Datasheets also have actual circuits that are already designed for you. Here is an example of what I am talking about. Look at this Datasheet for TDA2003 There is a test circuit but the actual circuit they provide you has already been figured out and a PC Board design is there as well. tda2003.pdf -
Also sometimes a regular jumper will ark and a wire will melt off the insullation under heavy load conditions.
New type of advertizing. Links to Home Depot.
Here is a Datasheet. and mor info http://www.analog.com/en/prod/0,,759_786_OP271,00.html http://www.analog.com/UploadedFiles/Data_Sheets/118777557OP271_a.pdf CD4013BC.pdf
Search results Pinout http://www.cpu-world.com/info/Pinouts/68000.html Product Page http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=MC68000 Referance Manual http://www.freescale.com/files/archives/doc/ref_manual/M68000PRM.pdf http://en.wikipedia.org/wiki/Motorola_68000 http://www.cpu-world.com/CPUs/68000/index.html http://www.semiconductors.philips.com/acrobat_download/applicationnotes/AN10118_1.pdf
Search results. CS9018(D..H) Si-NPN =SS9018 = SS9018 CS9021 Si-NPN =BF 495 = BF 255 Part Number = CS9018 Description = Bipolar NPN UHF-Microwave Transisitor Manufacturer = Various V(BR)CEO (V) = 12 V(BR)CBO (V) = 15 I© Abs.(A) Collector Current = 100m Absolute Max. Power Diss. (W) = 310m I(CBO) Max. (A) = 50n h(FE) Min. Static Current Gain = 28 @I© (A) (Test Condition) = 1.0m @V(CE) (V) (Test Condition) = 5.0 f(T) Min. (Hz) Transition Freq = 600M Package = TO-92 Military = N Sub nte108 http://www.nteinc.com/specs/100to199/pdf/nte108.pdf Part Number = CS9021 Manufacturer Name = Various Description = FVGFVG CS9021 Si npn 300mW 30V 20V 5V 30mA 150>C 100MHz 1 10MIN NSC TO39 Subs CS9021 2N3662 BF494 KT3117B BF495
Here is another related link. http://www.electronics-lab.com/forum/index.php?topic=5524.0 Hot to read Datasheets. http://www.electronics-lab.com/forum/index.php?action=dlattach;topic=5524.0;id=3874 -
Most test conditions are presented with set values for the components. This gives you a standard in which you can figure out other conditions with different component values. If you did not have the example to go by the math for figuring other conditions would be a bit more difficult. -
I also found a BIN file but I have no idea how to open a BIN file. http://www.eserviceinfo.com/download.php?fileid=4393
This Post Should be in Datasheet section. As far as I can see with the searches most say They are = or see m52777sp All I could find is this note in spanish and this part schematic
