hotwaterwizard
2,022 -
Posts posted by hotwaterwizard
Here is what I have on this. [attachment deleted by admin]
This topic has been moved to Service Manuals.
[iurl]http://www.electronics-lab.com/forum/index.php?topic=6939.0[/iurl] -
7555 sounds like a timer
2sA683
http://www.ortodoxism.ro/datasheets/panasonic/SJC00001BED.pdf
4614
http://www.microsemi.com/datasheets/SA5-27.PDF
723
http://cache.national.com/ds/LM/LM723.pdf
2N3055
http://www.onsemi.com/pub/Collateral/2N3055-D.PDF
2sD313
http://www.cj-elec.com/ebusiness/product_images/b/cn_b_2_1093.pdf
http://www.ortodoxism.ro/datasheets/WINGS/2SD313.pdf
http://www.dccomponents.com/products/Transistors/Bipolar/TO-220/2sd313.pdf
H1061
http://www.pmccomponents.com/data/TR/H1061.PDF -
By the way I don't work in that Factory anymore. It payed only $10 an hour.
I was a machinist (so to speak). I drilled holes, grinded parts ,used the Milling machine, Metal benders, Metal Punches (that shook the ground when the punch came down), metal lathe, large drill press, etc. then assembly.
I had no part in the design. I was a general laborer, that just did as I was told.
I work back at my old job now making over twice that much money.
I am a Service Tech -
What exactly is a "gang operated airbrake"?
GANG-OPERATED DISCONNECTS
Gang-operated disconnects are used where more than one phase of a circuit must be opened simultaneously. The most common gang-operated disconnect switches are the air-brake type manufactured in 200-, 300-, and 400-ampere ratings in all voltage classes from 5,000 volts up. They are used at substations, switching structures, and on the lines for energizing and de-energizing transformer banks and other apparatus. They are also used for sectionalizing. Although they can be motor-operated, they are more commonly provided with a switch handle for hand operation. This type of switch is ideal because it lends itself to operation from the ground, often permitting service to be restored to sections of the network without pole climbing.
http://www.globalsecurity.org/military/library/policy/army/fm/5-424/chap7.htm -
Believe it or not the Earth is the 4th wire.
That is why they call it Ground.
Read more about it here.
http://www.seas.upenn.edu/ese/rca/instruments/misctutorials/Ground/grd.html
Take a look at his site.
http://en.wikipedia.org/wiki/Electric_power_transmission
And this one.
http://www.wipo.int/cgi-pct/guest/getbykey5?KEY=01/69758.010920&ELEMENT_SET=DECL
Here is OSHA's Definitions for Ground.
http://www.osha.gov/SLTC/etools/electric_power/glossary.html
Ground: A large conducting body (such as the earth) used as a common return for an electric circuit and as an arbitrary zero of potential.
Grounded, effectively: Intentionally connected to earth through a ground connection or connections of sufficiently low impedance and having sufficient current-carrying capacity to prevent the buildup of voltages that may result in undue hazards to connect equipment or to persons.
Grounded Conductor: A system or circuit conductor that is intentionally grounded, usually gray or white in color.
Grounding Conductor: A conductor used to connect metal equipment enclosures and/or the system grounded conductor to a grounding electrode, such as the ground wire run to the water pipe at a service; also may be a bare or insulated conductor used to ground motor frames, panel boxes, and other metal equipment enclosures used throughout electrical systems. In most conduit systems, the conduit is used as the ground conductor. -
Here is the Datasheet
UPC1204C Datasheet Pinout Schematic anything.
Rec/Playback IC 16 pin (NEC) -
CM5943 Search Results
2N5943=(CM5943)
ECG77 = MM8002 = 2N5943 = PT5943 = PT4610
ECG278 = 2N5943 = 2SC1199
Part Number = 2N5943
Manufacturer Name = Various
Average Price = 8.55834
Description = Bipolar NPN UHF-Microwave Transisitor
V(BR)CEO (V) = 30
V(BR)CBO (V) = 40
I© Abs.(A) Collector Current = 400m
Absolute Max. Power Diss. (W) = 1.0
I(CBO) Max. (A) = 10u
@V(CBO) (V) (Test Condition) = 15
h(FE) Min. Static Current Gain = 25
h(FE) Max. Current gain. = 300
@I© (A) (Test Condition) = 50m
@V(CE) (V) (Test Condition) = 15
f(T) Min. (Hz) Transition Freq = 1.0G
@I© (A) (Test Condition) = 25m
C(obo) (Max) (F) = 2.5p
@Freq. (Hz) (Test Condition) = 1.0M
Package = TO-39
Military = N
http://www.advancedsemiconductor.com/pdf/2n5943.pdf
http://members.tripod.com/~Malzev/comp/2n5943.htm
http://www.nteinc.com/specs/10to99/pdf/nte77.pdf
http://www.nteinc.com/specs/200to299/pdf/nte278.pdf -
1)CM5943
http://www.chipcatalog.com/Datasheet/AF92F0582870E114E21B87688F1AD598.htm
2)2N4960
http://www.nteinc.com/specs/100to199/pdf/nte128.pdf
3)2N3839
http://www.nteinc.com/specs/300to399/pdf/nte316.pdf -
ARRRRRRRR
http://www.lasermotion.com/StepMotor.html
one of many
Search Google with 50oz inch torque -
Can't find anything on this IC
Yes, you got it. The Test circuit would be a great starting point but, pay attention to the maximum allowed voltages etc. Alot of Datasheets also have actual circuits that are already designed for you. Here is an example of what I am talking about. Look at this Datasheet for TDA2003 There is a test circuit but the actual circuit they provide you has already been figured out and a PC Board design is there as well.
Also sometimes a regular jumper will ark and a wire will melt off the insullation under heavy load conditions.
New type of advertizing. Links to Home Depot.
Here is a Datasheet. and mor info
http://www.analog.com/en/prod/0,,759_786_OP271,00.html
http://www.analog.com/UploadedFiles/Data_Sheets/118777557OP271_a.pdf -
Search results
Pinout
http://www.cpu-world.com/info/Pinouts/68000.html
Product Page
http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=MC68000
Referance Manual
http://www.freescale.com/files/archives/doc/ref_manual/M68000PRM.pdf
http://en.wikipedia.org/wiki/Motorola_68000
http://www.cpu-world.com/CPUs/68000/index.html
http://www.semiconductors.philips.com/acrobat_download/applicationnotes/AN10118_1.pdf -
Search results.
CS9018(D..H) Si-NPN =SS9018 = SS9018
CS9021 Si-NPN =BF 495 = BF 255
Part Number = CS9018
Manufacturer = Various
V(BR)CEO (V) = 12
V(BR)CBO (V) = 15
I© Abs.(A) Collector Current = 100m
Absolute Max. Power Diss. (W) = 310m
I(CBO) Max. (A) = 50n
h(FE) Min. Static Current Gain = 28
@I© (A) (Test Condition) = 1.0m
@V(CE) (V) (Test Condition) = 5.0
f(T) Min. (Hz) Transition Freq = 600M
Package = TO-92
Military = N
Sub
nte108
http://www.nteinc.com/specs/100to199/pdf/nte108.pdf
Part Number = CS9021
Description = FVGFVG
CS9021
Si
npn
300mW
30V
20V
5V
30mA
150>C
100MHz
1
10MIN
NSC
TO39
Subs
CS9021
2N3662
BF494
KT3117B
BF495
Pioneer DEH-P3500MP
in Service Manuals
Posted
Here is the Service Manual [attachment deleted by admin]
